Bike Finder · Kona
Kona Remote 160
Kona
Remote 160 2023
DiscontinuedLightweight · EnduroLegacy · 0/10iFreshness 0/10
Motor
Shimano E7000 · 60Nm · 250W
Battery
Shimano BT-E8014 504Wh
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
View the Kona Remote 160 on Kona’s site
Kona Remote 160 2023
EMTB Forums verdict
The Remote 160 was Kona's value-focused full-power enduro e-MTB, pairing a 160mm-travel 6061 aluminium frame with 29in wheels and a Shimano E7000 drive unit fed by a 504Wh pack. Positioned as the more affordable longer-travel sibling to the Remote 130, it leaned on a no-frills component package rather than premium hardware.
Sold as a single build at 6299 USD, the spec is honest workhorse rather than flashy: a RockShox 35 Gold RL DebonAir fork and Deluxe Select+ Trunnion shock, a 10-speed Microshift Advent X drivetrain, SRAM Guide RE four-piston brakes on 200mm rotors front and rear, and grippy Maxxis Minion DHF/DHR II 2.5in tyres. Note that the Shimano E8000 in the crank line refers to the crankarms only, the actual motor is the lower-tier E7000.
Geometry is moderate by modern enduro standards: a 64 degree head angle, roughly 75 degree effective seat angle, a consistent 435mm chainstay across all four sizes and reach figures from 417mm on the S to 502mm on the XL. The 350mm BB height and middling wheelbase make it a balanced, approachable climber and descender rather than an aggressive race weapon.
The Remote 160 has since been discontinued, with Kona's later Remote 160 DL taking over the longer-travel e-MTB slot in the range.
Geometry read
Size
Descending
73
Slack 64° head angle, 160mm travel and a long 1254mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
55
Size balance
77
Front-long in L: 819mm front centre on 435mm stays (FC:RC 1.88). Planted and composed; rewards a forward, attacking stance.
Technical climbing
38
A workmanlike climber — expect to put in more rider effort on the steep stuff. 250W of peak power and 60Nm of torque.
Watch out forL runs front-long (FC:RC 1.88).
A 819mm front centre on 435mm stays means taller riders must actively weight the front to keep it gripping. The chainstay stays 435mm on every size, so L feels more front-long than the smaller sizes.
How it stacks up vs other Lightweight · Enduro bikes (from 16 bikes in the database)
Battery504 Wh74 Wh above average
Motor torque60 Nmclass-leading torque
💬 Forum discussion
Kona Remote 160
42 replies · 18k views · last reply 70 months ago
Join the discussion →
“Kona’s got a bike worth looking at. Definitely real Trail Bike geometry in keeping with their Process series. Not very many eMTB truly this progressive in the geometry. Rides great. Fits 27+ or 29 widetrail. Rides great! Shimano drive.…”
— sparrow · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach417 mm442 mm467 mm502 mm
Stack620 mm625 mm635 mm644 mm
Seattube385 mm410 mm450 mm485 mm
Chainstay435 mm435 mm435 mm435 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)75.1°75°74.9°74.8°
Wheelbase1198 mm1225 mm1254 mm1294 mm
Headtube115 mm120 mm130 mm140 mm
BB Height350 mm350 mm350 mm350 mm
Standover752 mm767 mm765 mm778 mm
Front Centre763 mm*790 mm*819 mm*859 mm*
FC:RC1.751.821.881.97
Trims · 1
Base
MotorShimano E7000 · 60 Nm
BatteryShimano 504Wh · 504 Wh
Travel F/R160/160 mm
FrameKona 6061 Aluminum Butted
ForkRockShox 35 Gold RL DebonAir 160mm Tapered 110 Spacing
ShockRockShox Deluxe Select + Trunnion
HeadsetFSA No.57E
StemKona XC/BC 35
HandlebarKona XC/BC 35
GripsKona Key Grip
SaddleWTB Volt
SeatpostTranzX Dropper Internal 31.6mm
BrakesSRAM Guide RE (calipers and levers)
Rear derailleurMicroshift Advent X
CrankShimano E8000 crankarms, 34t chainring
ShiftersMicroshift Advent X
CassetteMicroshift Advent X 11-48t 10spd
ChainKMX X10
DrivetrainMicroshift Advent X; Shimano E8000 crankarms, 34t chainring; Microshift Advent X; Microshift Advent X 11-48t 10spd; KMX X10
WheelsWTB ST i30 TCS 2.0
TyresFront: Maxxis Minion DHF EXO+ TR 3C 29x2.5" WT; Rear: Maxxis Minion DHR II EXO+ TR 3C 29x2.5" WT
Rides similarly
Spot a mistake?
