yet another chain lube thread
jbv
102
82
Vancouver Island BC
a couple of tips i thought i'd share. i like to clean and lube my chain by pedalling backwards by hand and it's impossible with many eebs. but is it? i read somewhere to put an allen key in a chainring bolt and it will hold it in place against a crankarm. it works brilliantly! yes there's a lot of resistance, and turns slowly but much easier to clean/lube chain.
i also decided to try the spendy Squirt wax eeb lube and it is also brilliant. clean, quiet, and long lasting. attracts no excess dust or dirt. love it.
Vas
31
18
Greece
A) Insert a small rubber/carton piece between the crank arm and the allen key at the point of contact to prevent chipping the crank arm.
B) I totally agree re Squirt..... the best solution by far! You should closely follow the instructions for optimum results!
BowenTheSheep
24
I tie one of the spider‘s arms to the crank with a ziptie, works a treat and you don’t have to worry about how you spin the crank, no risk of a allen key falling out.
mak
Dec 27, 2019
445
493
uk
Its not actually that hard to just put your hand into the front sprocket and turn it.
