Levo Gen 2 Turbo Levo 2016 Red 2 Lights On Battery
Turbo_Hero_SL
Bristol
Hi, does anyone know the why these 2 lights are red on my battery? When charging they also flash red, thanks!
Manfred
12
Do they not glow green either when you change the level (press + or -)?
Even if they don't glow green at this moment, they may be damaged by corrosion (water has penetrated), the red-green LEDs could only shine red (green was defective).
Pull off the button cover: Drive with a sharp knife under a lower round corner and carefully pry upwards. if it does not move, stop it, to newer batteries could be glued. Then you can check the LEDs.
look at the pictures
and here
(translated with google)
