SRAM Eagle NX (12 speed) to upgrade or not?
  • Thread starter Deleted member 1275
  • Start date
D
Deleted member 1275
Guest
Hi all.
I Had a nightmare of a ride yesterday. Two punctures and my rear mech somehow made it into my spokes and badly bent about three of them. The rear mech is also mangled - the jockey wheels are both at severely different angles to each other.
If my LBS can fix it thats great but if a new mech is required should I just replace like for like or is this an opportunity to upgrade and if so to what? Is the GX worth the extra ££?
Eckythump
832
680
North Yorkshire
If you go to a GX cassette you will also need to change out the hub driver. NX uses a regular splined hub, GX uses an XD driver.
D
Deleted member 1275
Guest
Thanks @Eckythump . Will bear that in mind when Lbs have done their assessment! (y)
