Potential water ingress 2022 Regin E’s
Rickster
291
282
Ok BC Canada
Does anyone have a plug to cover the 25m battery tightening/loosening hole ? I noticed that the rubber grommet on my 22 Regin doesn’t come close to sealing against the screw housing. There was at least a 1/4” gap, so I loosened off the two screws that hold the assembly in place and slid it over to contact the face of the housing. I double checked with a light from the outside hole and it seems perfect now.
Just a heads up 😎
Before realignment
After
Rubinstein
405
533
kent
I use tape on the outside of the hole and also the battery latch as if found these areas are good for crud and dust ingress, also you get the odd drip inside after washing. Cheap and easy fix, which is a rare thing in this game 😉
