lower front of Cube Hybrid Pro 140
xcentric
197
126
Market Drayton
My OH has just bought the above nike, and loves it - but in a small its as high at the front as my large Levo. I can remove a few spacers from the head tube stack to lower the bars, but the head tube is still quite high. Is there a relatively simple way to lower the front (apart from a smaller wheel, or a shorter fork?).
Or did others get used to it quickly?
I would suggest getting used to it first , aside from lowering the stem, you can also look at lower rise bars, or even a lower rise stem.
You can shorten the travel of the fork, depending on what fork it is, but this will change the geometry of the bike.
ggx
686
443
Sintra
I ride an S Hybrid 160 . Don´t feel it hight in the front.
They have some spacers if you want to try diferente Setup.
Kernow
1,436
1,149
Cornwall uk
Does it have a reversible stem , ie remove it and turn it upside down so it points down instead of up , that can make a huge difference . Plus what r120 said flat handlebars etc
