Kenevo SL KSL Rear Brake Hose
Doomanic
🛠️Wrecker🛠️
8,478
9,957
Has anyone fitted a new rear brake hose to their KSL?
Was it a PITA?
Did you need to drop the motor?
Doomanic
🛠️Wrecker🛠️
8,478
9,957
I'd need to cut the existing hose at the banjo for that to work which I'd like to avoid if possible.
Armeniandave
119
111
San Diego, California
I just swapped my brakes to Shimano Saints and used the barb and it
worked great. It is a little bit of a pain in the butt to screw it on, but it works.
I also made sure as I was pushing one side I pulled on the other side so that
there was minimal stress on where the barb Is connected.
Oct 25, 2022
40
56
Scottish borders
No you can do it with motor in. Feed from rear. You do need to take the belly plate off and it's easier if you drop the forks. Underneath it you can take the fed hose When look up the inside of the downtube you'll see a carbon sleeve, but of a faff but feed it up the middle. It'll pop out on the left hand side of the headtube just feed it through.
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,514
4,795
Helsinki, Finland
Old thread, but updated information.
I did the exchange yesterday. No engine or shock removal. I cut off the old hose right after the brake caliper and connected the old and new with the RS Barb connector. At the same time, the connector prevented DOT oil draining from the old hose.
The old hose was quite stuck, so I first sensitize it by pulling on both ends.
A surprisingly easy change. I was using Shimano SM-BH90 hose.
