Other JUST DROPPED: All-new Slash+ e-MTB
Regarding the bottom out comment..is this just not a setup issue? Bottoming out itself isn’t an issue but repeated bottoming is more likely to be incorrect spring rate.
It is more of a bike peculiar issue, I never bottom out that easily a bike, had the issue with the stock fox float and the vivid air, ultimately I had more token and a bit more HBO. This was the first time I experience this on a bike versus all my others.
Are you on Zebbs (9.9)? By front heavy, do you mean the forks dive into their travel? With 1 or 2 tokens they do, they lack decent mid support. With 3 spacers in the fork you get decent mid support from the Zebbs, not quite Ohlins level, but very good and there was no discernible loss in compliance compared to 1 or 2 tokens in my opinion.
Ive driven the KSL and it is indeed lighter. For what its worth I have an Enduro, and switching between the Enduro and Slash+ is easy, compared to Switching between a Gen 3 Levo and Enduro where the weight difference was very noticeable.
I like how the battery doesn't come too close to the head tube/stem area on the slash+, its one of the reasons I bought it. it was one of my gripes with the Levo. It felt much heavier.
It is not about travel issue but really nose dive. With everything that I do with this bike, I have to be very careful to pull way more the handlebar, be way more back etc to avoid issue during riding.
It becomes clear when I do big jumping, I need way more speed and force to make sure it does not dive.
I do not have the same issue for example on the KSL, I mean not by that magnitude, I tried faster rebound but up to a point it cannot stand that much etc.
I also think, and this is on me and Trek, the sizing of the bike is garbage. They remove the ML which is where I stand usually. At 5'10 and 73kg full equiped, most people took the L where I should have took the M, the bike is not as agile as I would like it to be and being in L ultimately for my type of riding is not great.
I think you should spend some time adding volume spacers. No idea what build you have but if its rockshox start with two volume spacers and add in a 3rd to see if you like it. Do a few rides and change pressures, see what works for you in trails where you get this nose dive.
3 gave me the mid support I wanted, 2 wasn't quite there but decent enough.
Better yet, have a reputable tuning company shim your dampers and apply their recommended settings. I have J-TECH in the UK do all mine, saves me messing about trying to figure out the settings especially when the base tune doesn't suit your weight (in my case I am 95kg kitted so don't think the base tunes suit a big boy like me).
I have a large frame for sale in NZ
$5k with warranty. Comes with 34.9 neo factory dropper and factory 2026 float X
Tqhpr50 Motor and battery (600km) headset and chainring. Ask me for photos. Frame is also invisiframe from new.
yeah might try to have a 3rd token, no way to get a proper tune as nothing exist near me, lack of knowledge unfortunately and for the vivid air they even stop supporting it due to lack of stock parts.
That is a tough one!
I just had my Vivid & Zeb fully rebuilt.
When I took it in, I said I might like a firmer compression tune on the Vivid. The shop suggested they should open it up first... ~10 months of riding and the oil was dark grey.
I had the Zeb damper upgraded to a 3.1 (just new shims & knobs) which has noticably more support than the 3.0.
Rockshox says we need full damper rebuilds every 200hrs, and Fox says 125hrs. That is like 4-6 months max of relatively light use on an eBike. Tough if you don't have a good local suspension tuner.
Regardless, nose-diving does sound like less sag, or adding volume spacers to the fork would be the fix. I don't think it would be a reach issue.
Just a quick note on the updated TQ motor from somebody who just got a 2026 Slash+ after having their 2023 Fuel EXE stolen. A week ago in Australia the prices for a Slash+ 9.7 in medium (either 2025 or 2026) were much more attractive than any Fuel+ offerings.
HPR50 vs HPR60 motor
Before buying my next bike I read/watched nearly all the initial review videos on the Slash+ again, as well as those on the new Trek Fuel+ with the HPR60.
Seeing such positive reviews from the likes of Vital about the HPR60, when the previous year they were underwhelmed by the HPR50, I decided that it was worth the AUD$1K extra to me, and got the 2026 Slash+ 9.7.
I have only ridden it for about eight hours so far, but am very happy with my purchase (albeit underwhelmed by the DB8 brakes). The motor is noticeably quieter, more powerful, and more efficient. And by more than I was expecting. It no longer drops from level 3 assistance to level 2 five minutes into a climb (to prevent overheating).
Combined with the bigger 580kW battery I am confident that I'll now be able to take on much bigger days than I could on the Fuel EXE (which simply isn't an issue 95% of the time, but it will be nice to have that capability a few times a year). And on my local 200m vertical descent, which is pretty rocky and rooty, but not that steep, I set a faster time on just my second ride than I ever did in the 90 times I rode it on my EXE.
Still pissed off that somebody stole my bike. But definitely finding the Slash+ is a nice little upgrade on what I had, which softens the blow a little.
I recently tried to contact TQ to see if they would lend me an upgrade offer from HPR50 to 60 as I saw some people having pretty wild discount.
Pray for me!
Hey Slash'ers
Jank Components (Eric Olsen) is now offering a much sturdier replacement taco/bashguards for the Slash+. I can guarantee they fit. They don't have the void that cracks easily like the stock ones, and they are much thicker too.
You may recognize Eric from Pinkbike Academy, or bikepacking between EWS races.
Check 'em out here
Any idea what the warranty turnaround time is on these bike's TQ50 motors (in the UK if that makes a difference)?
I've got a 2026 slash+ 9.7 arriving soon to replace a trek fuel exe.
I'm going to fit the following off the fuel exe
-oneup carbon bars
-magic mary radial tyre on front, haven't decided on a rear tyre yet, but probably big betty or maybe tacky chan.
-hope tech 4 v4 brakes
The rest I'm hoping to leave stock. Couple of questions -
-what are the bontrager line comp 30 wheels like? Can they handle a beating as long as the tyre pressures are high enough.
-anything else I need to know about the bike before I start riding it?
-oneup carbon bars
Those wheels are a bloody nightmare to seat tyres on thats all you should know
I Have read that I should remove the plastic/rubber rim strip and replace with tubeless tape, so will be doing that.
Has anyone put a coil on their Slash+? The back end is quite good even with the stock Float which I was surprised about but a coil was always planned. What spring rate and weight are those that have gone coil?
How are you finding the chain slap noise? On my first ride mine sounded like carbon cracking :eek: I've since been wrapping the chainstay in mastic tape which has helped a lot, but I'll likely remove all of it including the stock protector and try the VHS slapper tape next. Then possibly build a wheel with the E13 sidekick hub to settle the chain further if needed.
If its the same as the carbon ones on the 9.9 there's a plastic insert. Why on earth anyone would want one installed I do not know.
Just remove it.
I wrapped mine in VHS and much later removed the rear mudguard. Use an old inner tube if you have one.
Within a week for the many motors I've had replaced on my fuel exe
Wonder why mine is taking so long.
VHS Slapper tape makes a big difference. Much quieter than the stock stuff.
Strictly on chain noise: I'm on transmission and there is really no noticeable chain noise- this is about the quietest bike I've ever owned. I can't say if Shimano might have more slaps. I don't think a sidekick will benefit the Slash much due to the mid pivot.
If you are getting a loud CRACK sound, could it be bottom out? I definitely found the linear setting with an aftermarket Vivid (no spacers) and 30% sag bottomed out too easily. Adding 2 volume spacers was the fix.
Another chain noise suggestion - check my recent video
Bike shop thinks it might be bearings and its in for warranty, but I assumed this was chain noise for a couple of months.
Just whip the chain off and see.
Bike was fairly quiet all winter even in gritty slop.
I'm using cable actuated transmission. I've checked the chain length and that's good. I've gotten the noise to manageable levels with an entire roll of mastic tape but in certain terrain the cracking is still there. Definitely not a bottom out issue. Even on trails when I'm not using all the travel I can get the cracking noise. I think its backlash in the motor causing the cracking noise when the chain pulls back sharply. Not too concerned about it but would much prefer it didn't happen. I'll check back in if I find out the cause and the solution.
Damm I really, really miss my bike, over 3 weeks with the supplier for a motor warranty request now.
Been riding my Gen3 Levo since, what an absolute brick of a bike in comparison. Makes me realise I made the right decision with the Slash+. Biggest annoyance for me is its weight around the headset area.
Yeah weird, that should be silent! Diagnostic check- is the chain still tight in smallest cog? wondering if the transmission b-tension needs to be reset.
Does anyone know how many tokens are inside the fox 38 170mm rhythm fork that comes standard on the slash+ 9.7?
Did install an Ohlins TTX22 . Changed the flip chip to progressive.
All good
98 kgs, 600 lbs/in rate
Did you fix the cracking noise?
I just picked up a brand new 2026 slash+ 9. 7 with the cable operated sram transmission 70. I went for the first ride and got a loud crack just popping off a small (6 inch high) lip.
It definitely wasn't a bottom out noise, it was actually pretty similar to the noise that you sometimes get on any bike when you change gear, but in this instance I wasn't chnaging gear.
It only happened once, the bike was quiet after that.
It seems like many Slash+ owners have experienced this, but nobody agrees on the cause. My hunch is that the "linear" shock setting is closer to digressive.
People are reporting this with different drive trains and shocks, so that reduces the variables other than the frame.
In my case, it also happened on my 1st ride on the bike, 1yr ago, on a very small drop, with an aftermarket vivid air & 30% sag. I added air and HBO and was fine on the rest of that ride (which did include some bottom outs, just no more loud cracking sounds). Afterwards I added 2 volume spacers and went back to 30% sag, it's been fine since.
Which one is linear? Front or rear hole?
    Join 43,109
