Thewootts
Good day,
I'm loving my E-bike but its my first plus tyre bike. I am really struggling with my tyre setup.
The Butcher grids that came with it were grippy enough i guess at low pressures the issue was they had zero support when pushing in corners and I tore the side walls twice in 3 rides. if i run the pressures high enough so they give the support i want and prevent destroying the side walls, the only way i can describe it is being in pinball machine the bike just pings and bounces off everything. At speed It's very sketchy.
I purchased a set of 120tpi minions 27.5x2.8 with the exo skin, as on my DH those tyres are fantastic.
Tonight was the first ride on the Maxxis . I started at 25psi literally hopped over the side on my first run popped off a root caught a rock and pinched the tyre putting a 2mm gash in the top and 1mm'ish gash literally just on top of the bead.
To say I was pissed was an understatement...
I am on the fence with either lacing a set of DH rims on the bike and running 2.4 tyres, or using some kind of cushcore variant.
Seeing the inserts are more expensive than a tyre for is what essentially a pool noodle. Just wondered if anyone has had the same dilemma and what route they took?
And are the inserts worth the money
