Other Gen 1 Battery 3 Flashing Red Lights
Turbo_Hero_SL
Bristol
Got a 2017 Levo battery, 3 red flashing lights also beeping. I’ve stripped the battery apart too look for signs of water damage. Slight bit of corrosion on the tcu which I’ve cleaned up but no other signs of water damage on the main bms/pcb. Anyone had any experience fixing this or manually charging the cells? Thanks!
Taffyteg
200
129
United Kingdom
Suggest you do a search to check for info on this - sounds as though the battery is dead though. There was a recall on Levo batteries, see if yours is part of that.
