thehornets
Hi , does anyone have the torque settings for my pro 500, the left crank keeps coming loose and the motor creaking a bit, thanks...
Thanks for your help...a few of us on here had the dreaded Gen 2 motor creak until we tightened up the mounting bolts
Yep...no problem. Is It the gen 2 motor you have with the small chainring?
Do u know the torque settings for the motor, im going to tighten it all up in one go ...thanksno problem. Is It the gen 2 motor you have with the small chainring?
Thanks again for your help , I'll let you know how i get on next week.I’ll find the ones I used and get back to you
Yes I do
I remember tightening the larger bolts to 24nm as that was the limit of my wrench.
the smaller torx bolts i tightened them up to a touch over 11nm. Problem solved. Not heard a creak since
I’ve posted a picture of some useful torques below which someone posted on here.
the creak was really annoying and it took me ages to work out where is was coming from.
I think what happens is the motor bracket is bolted on to a painted frame and the paint compresses over time. This allows some movement to develop and hence the creak. Not heard anything since.
Good luck!
[/QUOTE
Thanks for your help, i took it round to a friend who repairs bike and he torqued it all up for me. Went out today for a ride and its running sweet...thanksI’ll find the ones I used and get back to you
Yes I do
Good luck!
