Cube Reaction Pro 500
thehornets
7
Herts
Hi , does anyone have the torque settings for my pro 500, the left crank keeps coming loose and the motor creaking a bit, thanks...
Frankieboy
293
225
Basingstoke
If it’s a gen 2 (small front sprocket) I tighten my cranks to 40nm. This is below the recommended 56nm but I’ve never had them come loose. The torque setting is normally found on the bolt somewhere.
Beekeeper
🍯Honey Monster🍯
Aug 6, 2019
1,745
2,194
Surrey hills
Do u know the torque settings for the motor, im going to tighten it all up in one go ...thanks
I’ll find the ones I used and get back to you
Yes I do
I remember tightening the larger bolts to 24nm as that was the limit of my wrench.
the smaller torx bolts i tightened them up to a touch over 11nm. Problem solved. Not heard a creak since
I’ve posted a picture of some useful torques below which someone posted on here.
the creak was really annoying and it took me ages to work out where is was coming from.
I think what happens is the motor bracket is bolted on to a painted frame and the paint compresses over time. This allows some movement to develop and hence the creak. Not heard anything since.
Good luck!
thehornets
7
Herts
Yes I do
Good luck!
Thanks again for your help , I'll let you know how i get on next week.
thehornets
7
Herts
[/QUOTE
Yes I do
Good luck!
Thanks for your help, i took it round to a friend who repairs bike and he torqued it all up for me. Went out today for a ride and its running sweet...thanks
526K
