The Official BLEvo Thread
Status
Not open for further replies.
I have just released the version 3.5.1 of BLEvo for Android.
These are the news:
- Added the Speed Multiplier parameter to be able to use the bike sensor with a speed reduction system (see attached image)
- Now you can have the voice message every 30 minutes
- Added filter for barometer altitude values
- Optimized slope calculation
- Improved battery consumption on map display
- Now the AM / PM time is displayed if set in the system
- Added configuration parameter to automatically calibrate the barometer with GPS when stopped
- The minimum HR legs power lowered from 60% to 10%
- Now the GPS distance takes into account the slope
- Now if there is no Strava authorization, the button is enabled and executes the Strava authorization request
- Bugfix: barometer calibration at startup
- Bugfix: GPX import with single line point
- Bugfix: storage of zoom level
I am using the LSS planetary gear magnet system to give 1 magnet revolution for each 1.5 wheel revolutions. Will this speed multiplier correct the speed and distance from the bike ? Right now I just set Blevo to always use GPS data. Thanks 20190619_140958.jpg20190619_183054.jpg
Would it be possible to add mapcarta to the map sources?
The quality of mapcarta exceeds all other free map sources I've seen. The link address of download button (in bottom left corner) shows that map data is provided via api.mapbox.com
BLEvo update: i’ve been using blevo for about 9 months now. i have an iphone but i bought a bv6000s for blevo on the handlebars. I LOVE IT!!!
i love all the data: cadence, hr, speed, distance, all broken down by level of assistance. always knowing what my battery percentage is, hr is, level of assistance is. awesome. being able to see and afterwards analyze what im doing, has extended my battery range tremendously!
my favorite data is the map. i use osm hike bike and download the areas i will be riding before i go. i know i could use many maps to navigate, but on blevo, ive got my hr and battery% right there on my screen with the map, and i can easily swipe up and down to toggle between full data display and navigating. cannot do that with just a map app!
thank you thank you thank you paolo for creating and maintaining such an awesome tool! it’s the best reason to ride a specialized! also, thank you rob and all the emtb forum family for showing me the way! i am LOVING riding my emtb. #ridetolivelivetoride ??❤️?⚡️??‍♂️?
I don’t see any advantages to other openstreetmap based maps, in fact it’s much worse than what is included with Blevo since it is not at all MTB or path focused.
Hi Paolo,
Just a quick question - what should the maximum "motor efficiency" be? Today on a ride I managed a motor efficiency of over 100% - is that possible?
Hi Paolo,
"motor efficiency" is the rapport between wh motor and wh battery consumed.. if it is 100%, all the battery wh are used for motor assistance...
The value could be wrong if a second battery is connected..
Paolo,
The last release of the android fixed a problem I was having on the LG-G5 that I had not reported but appreciate the fix anyway. On the prior version every few seconds the power from rider and motor would drop to zero every few seconds even under power and then bounce back. On this release it's working perfect. Love this application. Thanks for making it work.
I have only one battery. Last ride the motor efficiency was 101.7 %. A bit funny reading. I assume that motor and battery output readings are coming from interface and there is no calculation in BLEvo app?
Only one battery, motor efficiency shown as 101.9%
Paolo,
I think the issue was in the TCU, not in BLEvo..
Very strange.. the wh of the motor are calculated by BLEvo.. maybe there is some bug..
Hi,
New to the site and with the large amount of questions on this site, I apologise if I am repeating an existing and already solved issue I have with BLEvo:
I have now ridden the exact same route 4 times using BLEvo. 3 times on Android and once on iPhone. I know that the route is just over 10.5mls, yet with BLEvo I get 4 different distances ranging from 4.18mls to 10.8mls (last one on iPhone - likely the correct distance). All 4 times I get identical gps mapping but different distances.
What am I getting wrong??
Thank you for any helpful thoughts!
Hi,
Could you share the setting of the usage of the bike sensor or not?
Did you unlock the speed?
Not sure what that would be. Nothing changed in the bike firmware or the LG G5 cell phone OS during the time that this went away. Not complaining I like it now. All good.
Which TCU version you have?
Anyone else using iOS 13 beta with blevo?
If so make sure you except the Bluetooth on question. I accidentally denied it amd
It took me awhile to get it back up and
Working. But blevo is working perfectly with beta .
Is there any way of disabling the gps in BLEvo?
I use my Garmin to record the ride and upload to Strava. And I use the phone to control the bike with BLEvo. With the gps not active when using BLEvo the phone would use less battery.
You can switch off after starting the tour...
I never test it, but I think it works..
Thanks for the great app, the data collected is very useful for evaluating rider effort, etc. I am having difficulty when changing user settings when switching between saved sets, for example user 1 and user 2. Often it takes 3 attempts of choosing a set from the drop-down menu for the settings to be correct instead of being partially correct and showing "advance user" in the menu window. Also it seems that the speed multiplier effects all sets of settings and cannot be different for different saved sets. I am using the android version on a Samsung Galaxy s5 mini. The bike is a 2019 Turbo Levo Expert, TCU 3.025. Thanks in advance for any help on this.
The speed multiplier is a unique setting.
For user settings, it depends how many changes there are between one setting and the new one.. Some time not all the parameters are written at the first time...
I'm happy to notify the new version 3.5.0 of BLEvo for iOS.
Offline maps are now available!!! You can find it in the GPX menu.
These are the news:
- Added MapBox offline maps
- Wh of the second battery also displayed in the bike monitor
- Added Strava description with ride data
- Bugfix
Status
    Join 43,192
