New CEF69 bafang m510 and bafang m560 and cef50 bafang m820 frames
Actually they all do differnet things, K1 Fash is firmware, PedalPass is app based to controller to change settings with other things logged from the Motor and connect to Strava, Simalar to Bafang go but more features, I like on the BBR i can quickly change speed by +++-- on switch so they all do differnet things.
Im not familar with that screen, I know on the screen the CEF69 DPC030 from this Thread doesnt have the ability to do that. Do you have a CEF69 with DCP010? I know on my Bafang go app you need to navigate to upload that to strava thats useless if you want to ride a trail and upload you dont know where your going half time not to a physical address. I guess you don't need it :)
Not real good for me i will proably stack alot LOL atleast you have backup if screen fails, Didnt you want to try eggrider? I would but no where to put it unless i remount it in frame, Dont worry iv considered it to 3D print mount, i ordered UART one sent it back and changed mind again, then chatted with fellow aussie for pedal pass sovled my no work effort upgrade. BBR is good too the V2 has some differnet features. Hidden in Australia they just assume its moded and by by to bike laws getting bad downunder :(
Vedremo io in paese uso 25kmh mai al max e comunque sarei curioso di provare pedalpass ma costa troppo secondo me
I noriced a nice Camo Cef69 on 4Leaf FB with a 4 pin chargeport. What could that mean? Also the “bridge”. Will that make a big difference? In what? I am pretty happy, but also a novice rider.
Edit: no bridge on that bike.
Edit: hmm.. only 2 pins are used in the Bafang situation. my Yamaha PW has a communication line in the chargeport. But this is nothing but a different connector.
hi. I think there are 4 pins, 2 for charging and 2 for the range extender, because the range extender goes through the splitter.
and the seatstay bridge is the connection between the seatstay bars. it additionally stabilizes the rear end. the first model cef69 does not have a bridge, the new model does.
Ahh, range extender! Clever!
Dovresti avere un cavo per la ricarica da inserire in quella porta per ricaricare la batteria serve e anche per metterne un altra
Se guardi nella foto si vede che é collegata la seconda batteria
Finally First ride to work since the new linkage,
I also upgraded the M510 FC 4.0 to 16A so same as the RS Runs about 800+ Watt now, Didn't want to push it to far, Also range extender doesnt fit if your to have big shock, Just thought id mention that.
how did you upgrade it? firmware for rs?
I uploaded with Open Bafang tool and changed to 16A i know RS is 16A as i put in motor previously and checked but wouldnt work becasue of the sensor, got .5kph, I wouldnt recomend people doing this unless you are sure you know what you are doing.
I put it back into besst and read it, saved then i went back to Open Bafang tool to see if it stuck and it did, Only issue there is no way to download firmware from Open Bafang tool as believe. But if you want firmware i have all 3 x 36 v 48v for M510 FC4.0 and 48v RS from Dado. Iv given him firmware so maybe he will do some new firmware. only touches 800w for few secs so shouldn't overheat.
What is your BB height? Any issues with pedal strikes with the new link? Bike looks sick!
With a 180 mm fork and an offset bushing on the rear shock, I still ended up with a 350mm bottom bracket height, which is great. The new link might have help.
I’m also running 160 mm crank arms, so I’m very confident I won’t have any pedal strikes, even through rocky gardens.
Can you please share what frame downtube protection are you using?
The downtube protector is just a piece I cut from a rubberized old car door protector. The length is perfect, but I still need a better adhesive to keep it securely in place.
Anyone getting carbon creak sound from the frame (motor area i think) when pedaling? seems to get worse the more torque i put in but unable to fix it so far, its really annoying :( If anyone knows something for help would appreciate it.
Edit: I saw some people talking about a slight motor gap and i also have that, ill try to add some small washers there. My gaps are not that big so i had to order some quite thin washers but im fairly certain the sound is coming from there, ill update you guys later as its useful info.
Maybe
A con el cuadro cef 69 y motor Bafang 560 ... alguien podría decirme en talla L cual es la longitud máxima de tija que entra dentro del cuadro
Guys Quick question,
has anyone able to record a ride with the Bafang go app and the DCP030 HMi i cant see to ever get it to record a ride in ap and, Doesnt upload to strava either, Is this limitation of the HMI or im missing something.
Cheers
Did the washers help? I’ve got a couple of small creaks not sure were they are coming from. I’ve greased all the pivot points.
Hey sorry, really bad weather here for some time ill update later when i can take a proper ride. The washers i had to use were only 0.4mm thick but it seemed to fill the gap, hoping it fixes it.
    Join 43,134
