HmmmThink Permatex package this ^^^, wonder who actually manufactures it?
When I first saw your response post I thought you were gonna guide me through the “self-ignore list” method. After consideration I changed my mind …I might be trapped in a time-warp-loop.Dont forget your 25% off with your PRO deal!
I added Galfer Purples to the b1 kit and find the brakes to be perfect for me.After testing the Maven b1 kit on my wife’s bike. I put a set on mine.
Yes I do think they modulated way better now.
Up next
150-155mm Crankset.
I may give some Absolute Black pads a try. Seems to be just enough online about them, to “bite” the bullet.I added Galfer Purples to the b1 kit and find the brakes to be perfect for me.
Whatsatt mean in Engerlish? Just asking.I may give some Absolute Black pads a try. Seems to be just enough online about them, to “bite” the bullet.
I like the Mavens, however they do end forward momentum a bit abruptly. It’s why I like them. Paradoxically……….
I could stand to lose less loss of speed from them, but I’m over satisfied with the current rate of speed loss.
just need to smooth out the ramp from fast to slow.
Will report if I switch to AB graphene.
Mavens are strong. I like them.Whatsatt mean in Engerlish? Just asking.![]()
That’s why I use the purples. Great modulation and easy to ramp up the power. I’m in the rocky desert so rear lock-up is less than wet soils but, before the b1 and galfers, I could inadvertently lock the rear in the asphalt parking lot.Mavens are strong. I like them.
Better modulation would be great in circumstances where a little is good and a lot is too much.
Absolute Black pads are said to provide better modulation. So I can slow down in finer increments. Means higher speeds overall.
(Edit…..in theory…..)
I gotta give you props for designing these up..…well done.Had another play with my DIY magnetic pedals.
I swapped the ridged aluminium plate the magnets were mounted on for spring steel.
I found that with the aluminium plate, while it did snap my foot into position the magnets would ride against each other and not allow my shoes to dig into the pedal pins. When riding got rougher this resulted in my foot rotating on the pedal and a lose of grip sensation.
With the spring steel the magnet can be pushed down allowing my shoes to also grip onto the pedal pins, the harder I push down on the pedal the more contact with the pins. They now feel just like regular flats with the benefit of the snap to position and the slight upward pedal stroke momentum.
I need to test them some more but it's looking promising.
I also need and use magnetic peddles. Many years ago (6or7) I sat down at my coffee table and drafted something that might work for me. I thought I was brilliant, amazing, trend setting, so friggen smrt…until I googled magnetic peddles. My hopes and dreams of becoming filthy rich were crushed.
Magped and Avery Hustle beat me to the punch.Both models are good but I installed Avery Hustle Magnetic Peddles on my bikes.
It’s a different motion or action for release for these peddles and pin placement and pin length can be configured for each rider or each foot.
Amazingly strong in a vertical motion but easy and simple in a horizontal motion. The audible “click” sound in my situation is helpful.
The Avery Hustle are heavy …but I’ve had numerous peddle strikes with them so they seem to be fairly robust.yeah totally agree, I like the click into position and they are surprisingly strong when pulling directly up, it has caught me off guard a few times for sure, Ive learnt to roll my foot off the pedals which seems to work best.
I had seen the Magpeds and Hustle versions, as well as the eye watering price. I just couldn't justify spending the money if I wasn't sure I'd like them, I made these to test the waters with the idea of upgrading to some proper ones later if I did like them, but to be honest now that I've made these adjustments I'm not sure the branded ones would perform any better. I'm sure the pedal its self will be much higher quality than the cheap Rockbros ones I'm using, however considering they are so cheap they're actually not bad and them being composite helps to keep the weight down. If i do wreck them they are easily and cheaply replaced.
I need a few more rides on them to really test them out for sure.
