I wonder if it will fit any Avinox motored bike.I wonder if this will fit on the Pivot Ampd??
There are many Avinox powered bikes. My question was in relation to the real estate available on the Pivot Ampd and interference with the shock or perhaps even the top tube.I wonder if it will fit any Avinox motored bike.
Ok. I read your question and also had a question.There are many Avinox powered bikes. My question was in relation to the real estate available on the Pivot Ampd and interference with the shock or perhaps even the top tube.
Why is this good news? Doesnt it negate the possibility of third party extenders?Any aftermarket extender that plugs into the charge port has been disabled by new firmware which is good news!
Back feeding uncontrolled raw voltage to a larger lithium battery is dangerous. Especially while discharging the larger battery. You are conflicting the BMS within and also fluctuating the motors supply of stable amps. Load sharing solution requires much more than a diode.Why is this good news? Doesnt it negate the possibility of third party extenders?
I am aware of that. How does it help you making extenders for the avinox ecosystem?Back feeding uncontrolled raw voltage to a larger lithium battery is dangerous. Especially while discharging the larger battery. You are conflicting the BMS within and also fluctuating the motors supply of stable amps. Load sharing solution requires much more than a diode.
As my module load shares without conflicting the OEM layout and does not interfere with the Avinox system. Especially bms-motor communication.I am aware of that. How does it help you making extenders for the avinox ecosystem?
The firmware would recognise it as an Avinox battery and allow it to power the motor. Whilst 3rd party batteries would be blocked.It looks like the Amflow extender plugs into the charge port.
Yes, that will be firmware to act like a separate whole batteryIt looks like the Amflow extender plugs into the charge port.
Not sure why people assume that everybody do multiple laps, many of us do and want to do long tours, not multiple laps of the same stuff, so a 10kg power station is not the solution.The firmware would recognise it as an Avinox battery and allow it to power the motor. Whilst 3rd party batteries would be blocked.
I concur with Trailwatts. You cannot allow 3rd party batteries to supply the Avinox battery or motor through the charge port. The consequences of getting it wrong could be catastrophic. Hence why I advocate the external battery and inverter suppling the Avinox high speed charger, for away from Electricity top ups.
Current firmware already contains support of the two battey.Yes, that will be firmware to act like a separate whole battery
Will only fit Large and XL frames on PX/ PR.
Not compatible with M1 or other brands using the Avinox system.
Prezzo grazie sono admin di gruppo emtbloverscersilis e credo in molti lo vorranno sulle loro nuove px.Abbiamo sviluppato un modulo di controllo per l'Avinox e stiamo per raggiungere le fasi finali dei test sul campo.
Si tratta di un sistema di sostituzione del cablaggio elettrico, NON di un semplice collegamento di una batteria da 36 V alla porta di ricarica!
Amflow non ha risposto alle richieste di chiarimenti tecnici, poiché molti produttori dichiarano che "la garanzia è invalidata" (anche se le batterie originali sembrano presentare problemi anche senza l'intervento di terze parti).
Le opzioni disponibili saranno da 252 Wh e 360 Wh.
Vi preghiamo di manifestare il vostro interesse compilando il modulo sottostante o inviando un'e-mail all'indirizzo [email protected].
I don't assume that. I have stated that the Amflow PR and a spare battery is a better idea than range extenders, for long tours. It's how I ran my Shimano EP801. With two 630Wh batteries. There is no fast charging with Shimano.Not sure why people assume that everybody do multiple laps, many of us do and want to do long tours, not multiple laps of the same stuff, so a 10kg power station is not the solution.
Most frames with cell layout of range extender along with shock reservoir will not even take a 400wh.Current firmware already contains support of the two battey.
The dual battery it is an Avinox offer and not Amflow only offering, as you can see on the Avinox web site.
In fact they mention that is compatible also with FS800 and FS600 that no Amflow M2/s model use:
So not sure why you are stating that is not compatible with other brands. Also they have gone public in multiple interviews that they will come out with a smaller one too.
Of course some frames maybe in compatible due to the available space but saying is not compatible with other brands using Avinox is not correct.
Indeed frame clearance is the issue, taking the RS 600 and making 400wh (assuming that they need to shorten it for the smaller Amflows but keep the same/similar height and witdth) would fit a L Verduro, but if as some rumors say 480wh then not.Most frames with cell layout of range extender along with shock reservoir will not even take a 400wh.
Only release has been for amflow with 600wh. Not disputing the Avinox firmware etc or options.
Seeing the design of Whyte frame and Yeti makes it impossible to fit the current 600wh or the proposed 400wh.
Time will tell.
I am riding the M1 now, only variable is M2s testing due to 1500w and the 700wh px battery.@ TrailwattsUK
Do you intend to make future range extenders compatible with the M1 ecosystem as well?
Re-designing and testing various components due to the load values being so high on such short cabling.Hows this coming along?
