AlbertCZ
Anyone have the same as me? Just after last update... Before update was everything OK...
Yep, having those too after latest updateAnyone have the same as me? Just after last update... Before update was everything OK...
I got the same. It went away after few times switching off/on. I hope this doesnt catch me mid ride one day!I got a battery error
Had the also an issue after updating on Firday. Battery not offical error message code 0x27030021, but the bike works finemy new ride after the latest fix disappeared when I tried to stop and sync and the next time I started the bike I got a battery error, they need to up their software game big time
Same here, did you fix it?Anyone have the same as me? Just after last update... Before update was everything OK...
Wow, that is concerning! It is an odd place for a crack. It is near the heavily stressed mount area where the upper link connects to the frame, but usually if the mount can't handle bottoming events the crack runs around the mount, not vertically up the seat tube. Having said that, I have seen a vertical seat tube crack or 2 before on other brands of bike, so it's not totally unheard of, and we also don't know what their layup schedule is for their carbon plies. It could be that there is some sort of an overlap in that area that didn't get sufficiently overlapped, or something like that, so it ended up being the weakest point in the chain and took too much stress as a result. Have Amflow given any indication of how they will be handling the issue yet?Frames from 2026, all in the size of L, 8 cases are known. I ask the support to comment on this point.
No, Amflow support recommends make an udpate to latest firmware 01.03.0217, I did it already in the meantime, but no change. All rides recorded after update 01.03.0216 are not possible to open and sync to Strava.. Shit....Same here, did you fix it?
had that happen as well - then deleted the rides that couldn't be opened and started a new (very small) ride just to check and it worked fine - was a really short ride thoughNo, Amflow support recommends make an udpate to latest firmware 01.03.0217, I did it already in the meantime, but no change. All rides recorded after update 01.03.0216 are not possible to open and sync to Strava.. Shit....
Update from today (Tuesday 23rd)
I have another observation - after last updating to 01.03.0217 data recording stopped working entirely. I went out on a ride and started data recording, just like I’ve done a thousand times before. Everything seemed fine; when I finished the ride, I stopped the recording and confirmed it - just like I’ve done many times before. And that’s it... Data didn’t transfer from the bike to the app on my phone. I tried everything possible and impossible, to no avail - simply nothing… The ride just disappeared… So I have to say that since the last update, instead of fixing bugs, they’ve just been piling up. This is really crazy and frustrating, instead of improvements, it’s getting worse and worse. It’s one big mess, and data recording has now become completely non-functional.
