There is no logic in that! But I might as well give it a try..I discharged the battery to 5% - according to the Bafang display. I charged the battery and it fixed itself - the engine starts again without any problem, every time. Check it out for yourself if it helps you too![]()
That is weird, since the newer softwares seems to have less output current.Have you noticed that the Bafang website states that the M820 motor is rated at 80Nm? Does anyone know anything more? Has there been any new firmware or changes made inside the motor?
Mine has been cracked since almost day 1Can anyone tell me where I can get a replacement bike charge port? Bike tipped over while charging and cracked the orange flange. Still working but I want to replace it.
Patdam, can I ask you of the cadence of your son, I suspect he has a slower or higher cadence than yourself ? I ask because I think its not the temp setting thats limiting but the way the motor torque sensor is setup. I could repeatidly go into this so called temp problem on one long hill I have which flattens out a small amount about 1/2 way up. I've always blamed the long hill but that same over temp symptom always is on the flatter part.With it it can ride with me with my full ebike and It can climb in boost long time whitout any power variations. rider wheight make a big différency to reach (or not) of the motor temp limith
hi. i can only said my feeling, not "scientific". I used more RPM than him. But the most important differencies is in the rear sprocket position. He use less teeths than me (To the point i have replaced my 30 teeths front plate by an 32 for him). He feels that motor functioning better when it is under constraints. i had the same feeling when i used it, but on too short torque range. Raison why i use more short demultiplication and quick RPM. But with is low wheight (and young hearth), he can use it on more large torque range (without heating)Patdam, can I ask you of the cadence of your son, I suspect he has a slower or higher cadence than yourself ? I ask because I think its not the temp setting thats limiting but the way the motor torque sensor is setup. I could repeatidly go into this so called temp problem on one long hill I have which flattens out a small amount about 1/2 way up. I've always blamed the long hill but that same over temp symptom always is on the flatter part.
What it coincides is with me running out of puff and not being able to put enough effort at higher cadences onto the pedals. My normal cadence is up in the high 90's climbing, running out of puff and slightly less torque on the pedals I seem to drop back to about low 90's. I think the torque sensors program curve is dropping back into another part of its torque curve which backs the power back to about that 300 - 350 W's rather than the temp sensor coming into play. I should just buy one of Dado's little gadgets and find out definately.
So how do we overcome this. Well the sensor is programable, I can definatively say that. Let me get a bit more knowledge and how the parameters of the sensor works and I will come back but at this stage on my motor I can change the way the torque sensor works. If anyone who is reasonable computer skilled and has a M820 motor and wants to join in this ride then please PM me.
I also noticed what you are describingPatdam you and I seem to have similar weights and similar cadences with similar outcomes. I had predicted that you would have a high cadence if my theory is correct.
If I could ask if others using high cadences who are getting similar times where the power to the motor is cut back, if they could note that if they lower the cadence by say dropping a couple of gears and using more effort on the pedals, the motor watts is now back to more normal levels by checking on the watts on your display. Report back please.
I'm about 90kgs/195 pounds. In S+, averaging around a reported 400 watts of assistance, with a claimed 700wh battery, total bike weight about 44 pounds, Maxxis Minion DHR II + Assegai Exo+ tires, 3000 vertical feet of offroad climbing (around 900m) gets me to 17% battery remaining and dropped down to Eco mode.How wheigt you are ? i'm 100 kg, mine M820 on boost have power variations quickly and i never use it, I have seeted S+ at 80% to have stable assist (few used). I have replaced my 700 Wh battery by an 400 because i never used more than 50% of the 700. With mine M820 i can 30km / 1500 D+, but less quickly than full EMTB. Fot me it's a perfect ebike to ride with my friends whitout assist.
Now my son use it, is wheight is 60 kg, With it it can ride with me with my full ebike and It can climb in boost long time whitout any power variations. rider wheight make a big différency to reach (or not) of the motor temp limith
how remove the socket?remove the socket, run the cable through it (seal it well) and terminate the cable with a new socket.
Hey did you end up finding a solution to this problem? I find that I have a he same issue with the motor cutting out briefly then coming back on. It's usually when I'm in boost mode but I've still had it occasionally happen in other modes.Hey all, Looking for some troubleshooting help.
My m820 keeps cutting out. The entire display will reset and sometimes turn back on, sometimes it doesnt. Sometimes the power cuts out midpedal but the display stays on. Its a really weird issue.
I said it has to be a connection issue. So I took the motor out and checked all the connections on the battery and motor. I even tried two different controllers (dpc245 v3.0 and dpc245 v2.0) with the same results. Its very inconsistent and driving me crazy. Sometimes it will work for a few miles, then it will just cut out and not work and wont turn on. Is it possible my battery is bad? Voltage shows its ok. motor is 36v version with 720wh battery.
Looking for any ideas to go with it next. Battery seems good, controllers seem good, connections are all nice and tight... what should i look at next?
It look slike green bike kit has that gear. Or you might find it on aliexpress if that's easier.Hi all. Did anyone replace nylon n gear in m820 ? Where did you got it from ? Thanks
I have done about 370km and SZZS is not giving any warranty with the motor, so I took it apart myself. Just looking where to get the part for.
