Forbidden DreadNought E
If you are welding why have a floor that catches fire? Also if ya doing dirty stuff why have a floor traps dirt and grime?
this seems to me to be a clean mans garage that doesn't do any dirty or hot work.....
What am i missing?
I just cant think for a worse set up for both hot and dirty work.
Dont get me wrong. It clean and cool as fuck. Just doesn't look heavy workshop compatible.
There's usually shade from folks that haven't tried it ( just like forbidden's geo :p ).
If you're throwing stuff on to the floor while tig welding, you're doing it wrong.
And there's an advantage to the swisstrax "grid" tiles, in that spills and debris drop through it. One quick wipe with some paper towel and you continue working, no need to mop it up immediately. And then just pressure wash into the floor drain when the job is done. Or if just cutting/grinding debris, shop vac it up. The tiles hold stuff in place until you're ready to dispose of it essentially, but it doesn't contaminate your working surface (what your feet are touching).
There's a need to throw down a fire blanket when plasma cutting, but that's true of any floor, even bare polished concrete.
I'd not be hardfacing equipment implements in there or air arcing, but that's not what most people do in their garages either. Nor do I work on super dirty junk in there. Have a shop with an overhead gantry crane for those types of adventures.
Not discounting your personal experiences, but mine have been wildly (see what I did there?) different than your own. But the Wild does need a coil shock, due to its nearly 40% progression. An air shock will have lots of hydraulic lock, which will feel approximately like PK.
The new RS with the TQ40, which the new Avinox Wild is going to emulate, is noted for its extremely plush and DH focused rear suspension design (low Anti-squat) that is offset by the Neo rear shock.
You know, on second thought, the wild felt more like a vpp bike. Kind of more harsh around the sag point as well. Very similar to the crestline. It did wall up hard, but perhaps that was bottoming ?
Are you sure it's over 30% progression ?
It’s not that high. I think it’s around 27%.
It's really good, as is the arrival 170 I mentioned.
But you'll notice it more on things like multiple ledge drops, or moto style whoops, not necessarily single hits.
It's just an idiosyncrasy of the kinematics. Everything is a tradeoff and balancing act.
OT: Yah, I do lots of that sort of riding too. It's the plushest smooth bump eating suspension that I've ever ridden. But then I don't get to ride everything set up for me.
Here is the correct LR (30%, I had read once it was nearly 40% but clearly that was incorrect) from Avalanche's website. They just retuned my shock for the Wild and added a hint of mid-stroke support. I have (briefly) ridden Crestie's, a Norco HP bike, Sixfinity Yeti, etc. but I'm very picky about set up and only the Yeti felt really good.
I've got a couple hybrids and bombers from Craig, he does nice work. It's crazy that they're relatively old designs, and still outperform any off the shelf single crown offerings.
30% is pretty optimal for air.
20% is typically coil shock territory.
But there are some bikes (vpp 🤷‍♂️ ) that really benefit from coil, even in the 30% progression range. The acoustic dreadnought v2 is like that, air is horrible on it.
The yeti's six bar design was really good, probably the most "character" free rear end I've tried in recent years.
The e-dread is pretty decent on air, but I'm already eyeballing an ext coil for it. Just got to know...
Did you have this reversed?
I'd say 30% is pretty optimal for COIL;
and 20% is pretty optimal for AIR, in a long travel configuration.
In my experience the amount of travel (really the amount of time you have to shed off energy) is also a hugely important factor. For example, 30% & a coil on 170mm travel is excellent. But 30% on 130m travel (like my Smuggler) needs an air shock with some tokens for sure.
In my experience the amount of travel (really the amount of time you have to shed off energy really) is also a hugely important factor. For example, 30% & a coil on 170mm travel is excellent. But 30% on 130m travel (like my Smuggler) needs an air shock with some tokens for sure.
That's correct, sorry, not enough coffee this morning.
perhaps y'all have seen the Laurie Greenland test mule video -
I asked Cascade Components about their interest in making a custom link. I just got a DH38 for my DreadE and with 200mm up front, the 170mm rear travel seems mildly short. their reply:
We are curious about this bike but haven't seen enough demand just yet. Hopefully that will change, and we could take you up on checking out your bike.
I'm local to them and offered to let them scan my bike.
so if any of y'all would want more rear travel send them a message and perhaps we can get enough interest to make it worth their while!
Seems like that linkage / DH modification is allowing them to run 29 in the rear? I could be wrong in estimation, but looks like.
I've also tried 2 different Cascade links on different bikes (Evil and Transition Patrol) as well as the existing one from Crestline - I find it's better for the active style ride who likes to pop off things as they usually go towards higher progressivity. If linear / magic carpet suspension is what you like, I would steer away from Cascade.
I do wonder what the point of that test mule is though ?
The e-dread and supernought geo are not a long way apart.
Why not tweak on the supernought platform instead ?
Unless this is development for a supernought-e ?
Any Forbidden Dreadnought E owners having issues with up shifting? Mainly from 10th to 11th gear?
I have T1 build and have been struggling with this issue since I got the bike few weeks ago but no luck in fixing.
I don't think it's the derailleur. Maybe have something to do with high pivot system as they are sensitive.
It shifts fine on repair stand but when when I ride, it doesn't shift from 10th to 11th and when I press the pod again, it goes to 12th gear. Seems like when there is tension on the chain, it won't shift from 10 to 11th. 11th to 12th no issues at all.
Played with Micro Adjustment moving it out by 2 setting, then 10th 11th work but 3 gear gets messed up.
Tried everything including reset the derailleur/alignment, micro adjustment and more. End up taking it back to the shop I bought it from and they can't figure out the issue either.
They are going to reach out to Sram and Forbidden.
Anyone have experience with similar issue?
did you set the derailleur b-position (I know it's TType and they don't call it that, but I forget what they call it) while sitting on the bike / at sag?
I have found this to be an issue on every Forbidden I've owned - chain tension at sag is very different from in the stand. I don't even try fine-tuning shifting in the stand anymore, I just get it approximately right and go pedal around and finetune then
I was wondering the same thing, as I have been scoping the Supernought for a DH bike. I ended up purchasing one recently - I figure the SN is solid enough and I wanted a DH bike. but it does have slightly weird optics to publicize the (non)eDread test mule.
then axle path is substantially different - 34mm max growth for SN, IIRC. 18.5mm max growth for eDN
I had previously thought that some issue w/ the axle path on the inverted-4-bar was the reason Forbidden switched away from that to the mid-pivot-Horst for the ebikes. but I now think the shock tunnel placement interfering w/ the motor mount area is the more likely explanation?
I dunno, just speculating.
Very likely they’re looking at changing to a less progressive kinematic, and cutting rc growth a bit.
But that could have been done on the supernought platform.
I just purchased a supernought today actually.
Per Sram app, it says to use setting A on 6th cog (24t) which is what I set at. I did read somewhere that on high pivot bike (not specific to Dreadnought E) to set with sag but the issue is that I have coil spring in the rear so I would need another person to sit on the bike while aligning the derailleur. If it was air shock, I could release the air pressure so it sags but coil is bit more difficult.
I also have a coil shock and I have done a satisfactory-enough job by using a yoga strap looped thru the rim and the back rails of the seat, and cinching that down while sitting on the bike. then tightening the derailleur.
another time I was on a trip and didn't have the strap, and I managed to balance myself on my stomach on the seat (it was kind of painful lol), using my feet for balance but keeping my legs outstretched with minimal weight in the feet. I managed to torque the derailleur in this goofy position and it seemed close enough to work
We need photos! 🤣
I have not had any issue with either my dreadnought v2 or my e-dreadnought in setting them in cog 7, position b, full extension on the rear end.
So you don't have any shifting issue on Dreadnought E when you set them on cog 7 position B? Which tier do you have of Dreadnought E?
I do have question. If you set the derailleur while sagging the bike and let's assume it works. What happens when you put the bike on a stand to test gear shifting for what ever reason? Would that make it clunky shifting when bike is on a stand?
