boomdocker
Under certain pedaling load, my motor auto shifts from emtb (or emtb+) to turbo
I find this a bit irritating, how do I turn it off?
Do you mean the motor actually changes the mode to Turbo and this is shown in the display? Should't happen and is the first time I hear about.Under certain pedaling load, my motor auto shifts from emtb (or emtb+) to turbo
The former ie the motor changes to turbo from emtb+ and is shown on the displayDo you mean the motor actually changes the mode to Turbo and this is shown in the display? Should't happen and is the first time I hear about.
Or do you mean the support increases in eMTB and eMTB+ modes when applying more power to the pedals? This is the designed functionality of those modes.
Really strange.The former ie the motor changes to turbo from emtb+ and is shown on the display
I have had a bike with a gen 5 motor for a few weeks now and it kept changing modes without me doing anything. It was a bit of a bind .Really strange.
Could it be that your mode switch has a loose contact or the buttons get pressed by some other component next to it. What controller do you use?
Exactly, that's what I was thinking about.Then I discovered that a fold in the thumb of my glove kept touching the mode switch!
Apart from being 90 degrees away from each other, we are aligned!Exactly, that's what I was thinking about.
For me the more vertical mounting is ideal. When the switch is horizontal I tend to do multiple presses and have to rotate my thumb to far.
I simply followed the Bosch recommendation and it worked for me: How-to | Position control unit correctly - VideosApart from being 90 degrees away from each other, we are aligned!
1. Thanks for the warning!Yup. That's the most likely cause of the OP's observed symptoms. As much as I enjoy the Bosch motor, the Wifi Remote is şħíț on a biscuit.
1. The clamp is made from the eggshells of undernourished hens. Tighten it 0.1 Nm beyond the 0.6 Nm recommendation and you'll be ordering another.
2. Get a little heavy handed with rubber cap covering the switches, and it will assume the shape of a potato chip.
3. The switches are sensitive to the point that you can't be sure what's going on without checking the display.
The motor is made for hardcore shredders slamming it off rocks, but the switch is more suited to endodontists delicately loafing along the paved bunny trails.
2. What rubber cap?
I still don't see any soft rubber (cover or rectangular thing). See my pic. Have I got something missing?It's the soft rubber rectangular thing that you push with your thumb. You can pull up on it a little with your fingernail to see how it is, but don't pull too much or you'll break it. I goofed up the one on my 2024 bike within two months, and neither Pivot nor Bosch could get me one for several months. I ended up having to order one from Italy. During that time, I ran across the Pivot demo guy. One of his bikes had the same goofed up remote.
Luckily, you can get by without the remote by using the display.
@RustyIron Forgive my "Mister Euro-Exclusive fancy bike-parts man" manner.![]()
I have the part number and Googled USA suppliers for you:No worries, mate. If my existing switch and spare switch get broken, I'll ask you to send me one of your Newfangled Heavy-Duty Euro-Style switches. You can become an International Fancy Bike Parts Trafficker.
