boomdocker
Under certain pedaling load, my motor auto shifts from emtb (or emtb+) to turbo
I find this a bit irritating, how do I turn it off?
Do you mean the motor actually changes the mode to Turbo and this is shown in the display? Should't happen and is the first time I hear about.Under certain pedaling load, my motor auto shifts from emtb (or emtb+) to turbo
The former ie the motor changes to turbo from emtb+ and is shown on the displayDo you mean the motor actually changes the mode to Turbo and this is shown in the display? Should't happen and is the first time I hear about.
Or do you mean the support increases in eMTB and eMTB+ modes when applying more power to the pedals? This is the designed functionality of those modes.
Really strange.The former ie the motor changes to turbo from emtb+ and is shown on the display
I have had a bike with a gen 5 motor for a few weeks now and it kept changing modes without me doing anything. It was a bit of a bind .Really strange.
Could it be that your mode switch has a loose contact or the buttons get pressed by some other component next to it. What controller do you use?
Exactly, that's what I was thinking about.Then I discovered that a fold in the thumb of my glove kept touching the mode switch!
Apart from being 90 degrees away from each other, we are aligned!Exactly, that's what I was thinking about.
For me the more vertical mounting is ideal. When the switch is horizontal I tend to do multiple presses and have to rotate my thumb to far.
I simply followed the Bosch recommendation and it worked for me: How-to | Position control unit correctly - VideosApart from being 90 degrees away from each other, we are aligned!
