Avinox SRAM AXS Motor power Cable (M1/M2 Variants)
Good to know, thanks.
Great price for the M1 version. Ready for conversion to M2/S version
I picked up an M1 cable last week for 50 quid, Just need the AXS mech now to replace my cable Transmission, which is really good in all fairness
Got my hands on one. Only $35
DJI is currently custom making these AXS extension cables and has essentially taken over production for Sram. I should have 30 of these soon. Hopefully they will arrive in time for our first batch of Teewing frames.
Can I buy one from you? Please!
Problem will be that different light cables require different connections. And different AXS power cables also use different colours and different polarity. So it's always going to come down to the user must verify the wire colours and polarity of both the SRAM AXS power cable and the Light Cable.
I have already made a post on how to verify the wire colours and polarity of the SRAM AXS power cable, and posted a picture.
When I have the M2S motor, I'll make the same post on how to verify the wire colours and polarity of the motor wires when you plug in the light cable and it's bare ends left free. Also with a photo.
do you have the M2S yet?
Yes. I posted my results.
AXS Cable built and installed, and new S1000 derailleur fitted. I have tested everything including Smoothshift. Everything works perfectly. It was as I previously posted.
SRAM AXS Power Cables.
Black is the Positive +
Blue is the Negative -
https://www.theoddspoke.com.au/sram...jLIn6P7ms6rmj9dbV8hWcao7vfBe_dNHgsy5Pk6DaIDJN
I have the Ebike24 cable.
Red is the Positive +
Black is the Negative -
DJI Avinox Light Cable 500 mm | eBike24.
With my two cables the correct wiring is. AXS Cable Black with Light Cable Red. AXS Cable Blue with Light cable Black.
I have a Bosch cable (with the Bosch end cut off), and M1 Higo, and an M2(S) Higo going spare of anyone in the UK is after one. Bought while waiting on my Druid before I knew about the change, and the M2(S) after I knew but before I got my frame (didn't know which tier I'd be getting).
I'll get pics up tonight
