Specialized Warranty Expired - battery failure, what are my options?
@cream
Afternoon,
You seem to be the person to talk too!
I have a 2019 Specialized Levo turbo with 700wh M2 battery, 54 charge cycles.
The other day, it stopped working. When I plugged it in to charge, the third of four green lights just flashed for a while.
Left it on charge overnight even though the charger didn't seem to be putting in energy. Flipped the charged on and off a few times to try and kick it into life. Couple of days later I walked past and flipped on the charger and it seems to have come back to life!
Just popped it into bike and it seems to work.
Took the battery to dealer for a check, Their diagnostic software says the battery is totally dead. Put it back in bike and it still works.... Did advance diagnostic test, phoned declare and they can't see any error messages...
Forums suggest the third green LED flashing is not good news. I suspect the BMS is locked out after the battery was left by previous owner for a long time on low charge over winter.
Any thought, help/advice or services you can share much appreciated. I'm based in the UK. Could post over or potentially post over the BMS only if you can provide simple advice on how best to safely remove/pack etc.
Cheers
Stu
Hi Stu,
Normally I could help but I need the battery in our workshop for a proper diagnostic. Being in Uk, complicate things because of customs import taxes, and higher shipping cost. Even if you sent only the BMS, this won't necessarily solve your issue if it's cell related, for example, or if you do a mistake when reassembling (you wouldn't be the first :)...working with powered circuits requires experience and extra attention. Especially when working with Li-ion batteries. Battery case is also not easy to open without damage. At the end, you must reseal it.
From your description, it doesn't seem the BMS is locked. Once it's locked, there's no way you can charge it or discharge it (aka the bike won't turn on at all). Rather it's an error/warning that's not permanent.
Also, if the bike powers on, then the dealer should have been able to do a diagnostic. There's no way the bike is working without proper comm with the battery. As long as this is working, dealer should also see the battery on their tool. An export of the error log would tell more about the cause for error.
In any case, presently is the battery working correctly ? (charging/discharging)
Hi,
I’ve replaced the cells in a Specialized Vado battery, but unfortunately the BMS has locked and the battery won’t charge.
I’m reaching out to ask if you could help me unlock the battery. I’d really like to get in touch with you, as I’ve read that you have a lot of experience in this area.
I’m willing to pay for your assistance.
Best regards,
Hi,
Best regards,
If it powers on the bike but won’t charge, you might have problems on the BMS charging circuit(it happens on this model). If not discharging or charging, might have a permanent failure flag activated in the firmware.
You can send the BMS board and I will check/repair it, as long as you are located within EU.
P.S.
Have you checked all balancing connections and NTC sensors when reinstalling the BMS? Is the pack balanced within 20mV?
I’ve checked it – both the MOSFET and the fuse are fine.
It has definitely triggered a fault flag.
I tried pulling the pins to ground, but it doesn’t change anything.
This is a customer’s battery, so time is critical for me.
P.S.
How much does a specialized m1 battery cost?
P.S.
hello, write me your contact details to send the battery for repair [email protected]
Yes, I can help. Next time you disconnect the BMS make sure it's completely off (the safest way is to put a jumper on the reset tactile switch.
PM sent.
@сream Good evening, I also replaced the elements myself and the board also got blocked, can you help me? Write to me in Telegram @rasendvov1 or by email [email protected]. I will wait for an answer)
Bonsoir @cream, j'ai également remplacé les composants moi-même et la carte est toujours bloquée. Pourriez-vous m'aider ? Contactez-moi sur Telegram (@rasendvov1) ou par e-mail ([email protected] ). J'attends votre réponse.
Si le vélo s'allume mais ne charge pas, il se peut que le circuit de charge du BMS soit défectueux (cela arrive sur ce modèle). S'il ne se décharge ou ne se charge pas, un message d'erreur permanent peut être activé dans le micrologiciel.
Vous pouvez m'envoyer la carte BMS et je la vérifierai/réparerai, à condition que vous soyez situé dans l'UE.
PS
Avez-vous vérifié toutes les connexions d'équilibrage et les capteurs NTC lors de la réinstallation du BMS ? La batterie est-elle équilibrée à ±20 mV près ?
Ma batterie fonctionne encore, mais elle ne se charge plus complètement et un voyant rouge est allumé. C'est une batterie de 460 Wh. Serait-il possible de la remettre à neuf ? Serait-il également possible de la remplacer par une batterie de 500 Wh ou 700 Wh ? Merci d'avance.
Hi @cream can you help me with an M2 700wh battery that now has 3rd led blinking when plugged in. Power won't switch on on the bike. Only 49 cycles and was showing 100% healthy last week. I'm based in UK.
PM sent.
Hardware wise, the BMS is the same on both 500Wh and 700Wh models. Both are using 21700 cells in 10s4p configuration, but the 700Wh model uses higher capacity cells. The firmware is different and that's what needs to be modified in order to use for example a 500Wh BMS to
M2/M3 batteries use 21700 cells, M1 is using 18650cells.
Hardware wise, the BMS is the same on both 500Wh and 700Wh models. Both are using 21700 cells in 10s4p configuration, but the 700Wh model uses higher capacity cells. The firmware is different and that's what needs to be modified in order to use for example a 500Wh BMS with a 700Wh pack.
Hi, can you send a pm, thanks.
Hi, @cream I have two specialized gen1 batteries and neither of them were charging. So, I desoldered the entire main circuit in one battery and soldered it back in the order it should be soldered. It started responding to the charger, but a short circuit occurred and now it no longer responds to being turned on or to the charger... So, I started making the second one after desoldering the board and replacing one section of the batteries because they were swollen and soldering it back in the correct order. From three flashing dots, it became only one flashing red dot. When I connect it to the charger, it starts charging normally, but the output voltage is 20V, and on the sections 3.8V-3.9V, but the output voltage keeps increasing, only very slowly, as if it was trying to balance itself. But after about 15 minutes, the charging LEDs suddenly stop flashing and only one is left. green LED. What could be wrong with this battery?
I can help you with board repair/diagnose/unlock but in order for everything to work, you need to replace all the cells not just a single cell or a segment of cells. I can't figure out what is happening in your case. You said the cells in series have 3.8-3.9V but then again you said the output voltage is 20V. That doesn't make any sense.
@cream I have a Levo 700wh BMS that has the stupid flashing third green light. I would like to send you the BMS for you to see if you can reset it. I’m pretty sure it’s due to being left with low charge for too long. Please can you email me [email protected] so we can arrange the details of where I send the BMS and payment etc.
thanks
Mike
Hi @cream,
We are a small company of 2 staff, based in Cape Town and Johannesburg , South Africa.
We repair ebike and escooter lithium ion battery packs. Recently we had enquiries for repairs to Specialized battery packs.
As shipping to lithium ion battery packs to Europe is a challenge, there's an option where we remove the bms and ship it, so that you can effect the repairs.
We can perform the recelling or repacking or cell repairs locally in SA. And then refit the bms that you have repaired.
Is that an option that we can explore? We currently have a Specialized with the 3rd LED flashing. Have checked the voltages and cell group 1 is at 4.2v and the other 9 at 4.1v. Battery pack accepts charge, then goes into the 3rd led flashing mode.
My email is [email protected]
Regards
I have a battery with the following issue: the LED near the processor is flashing, and when I press the button, only the two outer charge level LEDs light up. The battery was previously sent to another service center where the cells were replaced, so the BMS is likely locked.
What battery type/model is that? It doesn't seem a Specialized one.
That's correct, it's not a Specialized battery but a Multicycle one. I am sending you the photos of both the charger and the bike. An MCU reset doesn't help. The AN49511A chip seems to not be generating the alarm: NFAULT_M is 5V, ALARM_M is 0V.
The lock is in MCU not AFE chip (AN49511A). I could potentially help, but you will need to send the battery to our workshop. Where are you located?
HI @cream I have a SBC-B09 from a friend that made a short between the two charging pins and now it does not charge with the charger anymore - I have opened it up and charged it with my lab-powersupply successfully though.
The BMS board on the top looks perfectly fine and I am getting an output voltage when I switch it on, so I think most of it is still fully functional and there is probably just some fuse that needs changing.
Now to the question, can I just disconnect the balance wires without risking that the BMS gets locked? So I can take the pcb out and have a look at it from the bottom. Anything else to pay attention to, so it does not get locked?
How do I know if the BMS is already locked? It has this one led that blinks like once every second (see picture)
Hi. Your BMS is not locked (as long as it will turn on voltage on the discharge connector when you power on the battery), but if you remove the balancing connection(s), it will lock. The key to prevent that while you disconnect the BMS is to put the MCU reset line to a low level.
As you suspected, most likely SFC charging fuse is blown, check also the charging Mosfet for short. So either you replace the fuse while the BMS is connected or you put a jumper wire between reset line and GND, followed by a fully disconnect, replace faulty parts, reinstall, remove reset jumper wire.
P.S. I think we've talked in the past about an M1 battery BMS on pedelecforum.
Similar issue here (although I don't remember shorting it by accident, could be water), not charging but have output voltage (33V), turns on BLOKS display when switched on (and 3 out of 5 LEDs are green and stable, not flashing).
Haven't opened the battery yet, but if I understood correctly it should be SFC fuse and/or mosfet and I should be able to replace them without disconnecting and locking BMS (I have some experience with electronics and soldering).
Or is it safer to bridge that reset to gnd first before disconnecting everything (first button and LEDs and then what exactly: VP and VG or B+ and B- ?) and then do what it takes? Also I suppose the same procedure works for replacing cells (if needed)?
Thanks in advance, I'm also outside EU and without any Specialized dealer/service around so even diagnostics are unavailable.
Hi @cream
I have a Specialized SBC-B09 (604 Wh, Vado/Como Gen 1, board marked "Specialized ET Rev3", 2019) that discharges and rides normally but refuses to charge — no error shown on the bike or in the app.
I've opened the pack and done a full diagnosis:
- All 10 cell groups balanced at ~3.50 V (pack at ~35 V / 17% SoC)
- No signs of moisture, corrosion or leakage inside, seal intact
- Wiring from charge port to BMS checked, continuity OK
- With the charger connected, 41.5 V is present at C+/C- directly on the board
- Gate drive: all four charge FETs (AOD4286) at 0 V V_GS, the two charge-direction FETs of the main bank (IPB042N10N) also at 0 V — while the discharge-direction FETs sit at 10.5 V and the bike works fine
- Same behavior with two different original chargers (both stay solid green)
So the hardware looks healthy and the BMS is simply refusing to enable the charge path — which matches the permanent failure lock you described. Would you be able to unlock/reset this BMS? Happy to provide more measurements or photos, and I'm comfortable working on the pack myself (electronics background, proper equipment).
Thanks a lot in advance!
Hi,
As long as the battery is discharging normally, it’s not locked (Pf status set). Most likely you have a problem on the charging circuit. Check charging mosfet for shorts or low resistance and also check SFC charging fuse (close to the charging Mosfet). Most likely , that’s the cause for inability to charge. Very common fault on this battery model.
And how are we suppose to fix fuse and/or mosfet
Hi,
Thank you vety much for the fast reply! Do you mean this fuse?
Allright, I also got this specialized Vado battery.
It looks normal if you turn it on, 3 lights stable. But the charger does not see the battery, and the bike also does not turn on. According to the lights it should be half charged, which is about right with 37.7V across the pack. But the input and output are both dead.
Is this one possibly a locked one but still good? No signs of water damage or anything. (I put another battery in that bike and it runs like normal).
Can I send in this BMS?
I'm able to replace all cells spotweld them and all that, just no electronics. Can you help me out cream? Im situated in the Netherlands. I also have the option to get it serviced over here, but I'd rather just get the pcb unlocked, because it's possibly much cheaper. Is that possible with this one?And maybe I could also replace the cells with higher capacity ones...
O that little green LED next to the charge indicator is also flashing when I turn it on.
Upon further inspection it's also out of balance.... So I have to change the cells.
Can anybody explain how to disconnect the BMS safely and reconnect to the new cells? What's the procedure?In what order do I disconnect it?
Rokus
    670K
