Kilslow
I can confirm that the battery easily comes out when you remove the heat sink on the motor (just three more screws after you remove the cover). I swapped in a better set of brakes and pulling the battery revealed that there is a nice cable management system inside the tube. One tip for those on the same path, loosen the three mounts/screw (two for the bottle cage 6mm and the third below it). This loosens the cable management bracket so you can slide in the new cable easily. Very nice system. This is my second Pivot. They always get the small details right.
