sethimus
😠 Temu Gary 😠
so there are aditional parts we dont get with the frame? can you be more specific?These are NOT the top hat washers or shims. Your motor would not fit with these on the inside.
They did not come with the first batch to NZ but Velduro NZ gave them to the dealers. I got them and put them in. The next batches may have them included, I do not know but it sleeves the bolt hole and got rid of all creaks/noises from mine. Super silent now except minor motor clacking.so there are aditional parts we dont get with the frame? can you be more specific?
Here is the comparison of my SAR verse the RS Spring. I measure the SAR at 143mm. I think 146mm will just work based on my tests just now. The 2025 Vivid at 62.5mm on an L fits just fine too.Hey rob,
How much is to long? Rs have 151mm…
Thx
Great, Thank You!Here is the comparison of my SAR verse the RS Spring. I measure the SAR at 143mm. I think 146mm will just work based on my tests just now. The 2025 Vivid at 62.5mm on an L fits just fine too.
Size L & M are stock in Swiss. With or without Shock. VELDURO ROGUE Frame Only powered by Avinox M2sAny update for frame availability in Europe?? @vettatrade @Velduro Global HQ
Hello,Any update for frame availability in Europe?? @vettatrade @Velduro Global HQ
thx, i‘ll check if they are included now in the recent batch later today
Thx for testingSo, I was able to test the Hove MC in size M. At full bottom out, it touches the charging port cover a little. It might be worse under hard compression when the frame flexes. But I think you’re good. I also took the bottom out rubber ring off for the test. With the bottom out ring, it will stop earlier. You can also use a 2.5 mm stroke reduction.
There is also some space under the charging port cover.
I also made a video of the test, but I can’t attach it to the post.
View attachment 183172![]()
anyone got intel why there were new motor axles outside on the framebox to switch by the user?
What’s your build?anyone deleted the red m2s logo yet? thinking of just using a thin black permanent marker. can't have red with my colorway
i'll post it when its ready tomorrowWhat’s your build?
Check ALL bolts. 99% of mine were loose. Also, if you have the time, grease the pivot bolts. Some are greased, some are not.First Velduro in Romania! Build starts tomorrow.
The order was placed in February, I paid for the frame in full. Very happy.![]()
i had it at 11,2kg. bit higher than expected. moves my weight more into 24ish kgAlso somebody weigh their Velduro frame and motor system with the battery and post it.
Medium frame 10.9kg
Still finishing build but everything fitted except pedals and tyre sealant 22.6kg, with pedals 23kg.
still not finished -.-i'll post it when its ready tomorrow![]()
What frame weight were you expecting? What are some competitive frames coming in at? (E-Dread, Flux, RS180, etc.)i had it at 11,2kg. bit higher than expected. moves my weight more into 24ish kg
so i had the motor out of the frame today, those would definitely not fit. the motor sits flush in the frame, you need to wiggle it in. changed the read bolt to the newer one.
