Interesting, seen mixed reports from folk who have gone to coil vs air and the back again.
I was set on a coil but I think I'm gonna get the Vivid tuned with a WPS piston and see how that goes as it's feeling pretty good now after some more tweaking
My friends running ohlins 38 and coil on his 600 wh "lite" which is now basically a core. We both run carbon wheels and his bike feels as heavy as mine. Tried his prefer the feel of the vivid myself tho he is lighter so spring was proberly wrong for me.
Yeah, it's a look of cash to lay down on the coil I want as well (FAST fenix) but may just spend that money on getting the Zebs/Vivid tuned for me and maybe an AXS upgrade
Question current owners.
What sort of range/elevation do you get on either the 600 or 800w battery? Also roughly how much you weigh. Trying to work out if i go 600w for the weight (current preference) or 800w for the range on my upcoming dread-e.
Bit about me. 67kg's with all my gear. 95% of my rides are winch plummet, can easily get back to the car and charge up if needed (got a power bank already and have the avinox fast charger with the dread). Average ride is 13-18 miles with 1500-2000m vert. I'm coming from a Kenevo SL currently which i can comfortably manage the basic 320wh battery for the above rides with different modes and actual legs. I'm 'planning' on keeping the power around 300w-350w or less of assistance the vast majority of the time as all my climbs are fire roads. Currently all i get is 240w on turbo and that is more than enough for my heavy weight frame...
Any one with any real world numbers for me to mull over would be appreciated. Cheers.
That's how I have my core setup, Ohlins 38 (air) - 80psi main, 250psi ramp with recommended LSC/R, and 2 clicks of HSC for hard hits and a SDU Ultimate coil out back. Love that fork and shock compared to the stock Zeb/Vivid. I also built a set of WeAreOne Triad/Fuse wheels with OnUp Hubs to go on it as well as I destroyed the ARC rear wheel the first week I owned it.
I have a core with 800wh battery, I weigh 64kg, bike is about 24kg atm. Climbing fire roads all day, at 10-15mph in auto mode (which is usually around 150-400w assistance, with some peaks on 600w range in a few steep sections), Saturday I got 12000 ft (3600m) on 160% battery. (started at 100%, charged twice 40% each time, ended up with 20% left). I'm sure it can do better if tune it down some, but I prefer climbing a little faster.
Been also tempted by the direct wired in axs. Though not sure i want one after mine got smashed into my seat stay
im 92kg 6,2ft my battery does me a decent ride in trail, if i turn it down in auto can last ages. i love with the avinox you can just adjust all this as you go on the ride without phone needed.
Thanks. How much climbing/distance where you at before your first charge on the 800w? Also did you kill the battery before charging first time around or did you have some left?
I don't really know, I wasn't checking it during the ride. I charged at lunch time from like 40-80%, then let to drop to 0% up to 43% at 3-4pm and used about 20% more before leaving. Dropping to zero was a bad idea - though I did it on purpose - it caused it to go from about 30c to 45c in the last 5-10% and it refused to charge for a bit till the battery cooled down.
you should go with 600wh... not a battery for all but maybe for you.
'im on a 800wh, 74kg geared and can do 2200/2300m with no problem.
For 1500/1600 m 600 is perfect...2000 with a 30/45min recharge
leaning that way given the numbers you have all kindly replied with! Thanks.
I wouldn't mind trying the 600wh battery at some point, however l like weight, being light myself the extra weight helps imo. Also just not having to charge as often. I was really hoping one of the new motors (M2 or M2S) was going to be a toned down varient that focused on efficiency instead of pushing power numbers. Who really needs more power at this point, most of us tune it down anyway, I want more efficiency not more power. :(
Here is Saturdays ride - EMTB Forums wasn't letting me add it earlier.
question about TRanzX rad 170 on core3 S2... is it possible to increase travel like 180 or only reduce?
Unlike forks with where you can replace the air shaft with a longer one or remove spacers on some shocks for more travel, you can’t do the same with that dropper.
Tentatively asking, E Druid with a 600 battery, Tier 2, what sort of weight does it come in at?
Is there easy weight loss from factory (like better wheels etc)?
I quite fancy the purple haze.
Mine only goes -5mm -10mm or -25mm so I would say no. I ended up with a OneUp v3(which I like much better anyway) was able to get 210mm on an S2, using about 20mm more insertion than the numbers suggest.
Out making the most of the sun and dusty trails today
Rode purely in turbo with zero effort to conserve battery to get as many laps and trails in as I could.
23.16KM, 1236m vert and still had 19% battery left.
Probably would of had a bit more as well had I realised how much my rear brake was dragging to begin with it as well 😂
Also Zebs work better with closer to 30% sag than the 18% they had. Still felt good mind you but had noticed I wasn't using full travel even on big hits last time out. Don't really use sag to setup other than getting in a ballpark pressure figure but it's still like 20 psi less now than the trailhead app suggests 🤔
Maybe but it depends on what the cable is like on the plug as it is now the charging cable/port gets in the way of the cranks.
I'd get twice that mileage on a normal day with a full use of the battery tbh. It's rare I ride a full ride in turbo but was curious and it was warm
Just to follow on from Fridays ride.
Was out again yesterday, 34km and just shy of 1400m vert. Majority of the day in Auto which is tuned to 500/60nm IIRC and still finished the day with 39% battery.
I'm getting nowhere near that. I have detuned eco, auto and trail and treat them as low, medium, high. Staying in Eco or Auto depending on how much of a rush I'm in.
Did use Class3 and turbo for the first time transferring on Highway 9 in Santa Cruz for those who know the area. Only use I can think of wanting it. It would be utter chaos if you tried riding a shared trail or single track with those levels. Probably smoked a lot of juice in that little stretch.
Any rattle from the podioum fork?
1,000+ km in and the Podium is still… working. No oil on the stanchions, no air loss, no weird noises — honestly pretty disappointing. Was hoping for at least one dramatic mid-ride failure to spice things up. Instead, it just keeps riding like day one. How boring
    Join 43,113
