Dado
- Jun 28, 2022
- 1,057
- 669
- Thread starter
- #61
Hello. Thats not a good news throttle is not working.installed.
The throttle don't functioning (alike the M820)
the walk mode going forward at 5 KM/h, regardless of the position on the rear gear.
i need to build an bracket for the speed sensor and i could able to test it outside
I have not tested yet M510RS and not sure if this FC3.0 firmware it will take (but has new boot code 0x72 so I hope it will be a bootcode for RS controllers). This one should be with a throttle support.
Do you have also new display and hill holding function? Otherwise I dont see much advantage from this sensor. And I doubt it will serve as some "traction control".
