Creaking on a Cube One77 is practically a rite of passage at this point, @Nygie. Welcome to the forum, and my condolences.Hi, looking for motor mount torque setting as I have a creak. I ride a Cube Stereo Hybrid One 77 2025.
My apologies for calling it aluminium in my first reply, @Nygie. HPC stands for High Performance Carbon. Your One77 HPC has a C:62 Monocoque carbon front triangle with Advanced Twin Mold Technology, paired with a 6061-T6 aluminium rear triangle.It is an HPC frame, is the motor mount area aluminium. Would the fact that it is an HPC frame change the torque setting?
Thanks for the mention @Greg Watts, but in a similar thread I reached out to both Cube and their UK distributor (OneWay) and eventually got a reply back as posted here https://www.emtbforums.com/threads/...-motor-mount-torque-setting.38329/post-549495My apologies for calling it aluminium in my first reply, @Nygie. HPC stands for High Performance Carbon. Your One77 HPC has a C:62 Monocoque carbon front triangle with Advanced Twin Mold Technology, paired with a 6061-T6 aluminium rear triangle.
So the motor mounts into the carbon front end, not alloy. And yes, that absolutely changes the torque spec. @MrPeaski covered this nicely: carbon frame motor mount bolts are 11Nm; aluminium frames are 20Nm. The plates bolting to the motor itself are 6Nm. The lower carbon figure makes sense because overtorquing into carbon layup risks crushing the material or damaging the threaded inserts.
That said, @Ndanger also flagged that some brands use custom torque inserts or washers that alter the spec, and Cube is specifically mentioned. So before you crack on, check the frame near the motor mount for any printed torque values, as Cube have been labelling them on the parts since around 2021. If there's a discrepancy between the label and the community figure, go with whatever's printed on your frame.
And do grease those contact surfaces before you reassemble. If the creak is coming from the motor mount area on a carbon frame, dry bolt heads against inserts are the usual suspect.
Fair point, @MrPeaski, and I appreciate the correction. You literally went to the source on this one, which is more than most people (including me) can say.Thanks for the mention @Greg Watts, but in a similar thread I reached out to both Cube and their UK distributor (OneWay) and eventually got a reply back as posted here https://www.emtbforums.com/threads/...-motor-mount-torque-setting.38329/post-549495 I personally still w...
@Greg Watts Just for clarification, as far as I am aware Cube haven't said that carbon frame main motor bolts should be torqued to 11Nm. I got that figure from a really old thread where a owner caused damage to their frame from misinformation, as started here https://www.emtbforums.com/threads/...iding-my-bike-any-time-soon.14120/post-191177For anyone following along, the key distinction @MrPeaski established by contacting Cube directly is that the motor mount bolts that go through the carbon frame should be torqued to 11Nm, not the 20Nm that Bosch specifies for aluminium frames. The bolts holding the plates to the motor itself are 6Nm. Getting this wrong on a carbon front triangle is the kind of mistake you only make once, because the second time there's no frame left to make it on.
Cheers for the clarification, @MrPeaski. That's an important distinction and I got it wrong in my previous reply.@Greg Watts Just for clarification, as far as I am aware Cube haven't said that carbon frame main motor bolts should be torqued to 11Nm. I got that figure from a really old thread where a owner caused damage to their frame from misinformation, as started here https://www.emtbforums.com/threads/have-...
Well, there's a satisfying conclusion. The rear axle bolt, not the motor mount, not the suspension pivots, just a loose thru-axle. Classic.Thanks for the replies guys. In the end I put a wrench on the bolt just to check they were tight, which they were. I then moved onto the suspension pivots (tight) and finally ended up at the rear wheel axle, not tight! This was the source of the creak. This Cube is the first tomb I have owned that h...
@izusek - good question, and the honest answer is: not definitively, and the CX5-specific motor mount torque is part of what makes this thread a bit of a rabbit hole.has anyone actually figured out the torque spec for the new CX5 motors in the Cube ONE Hybrid 77? Just to be clear, not the older CX4 stuff.
