Sea otter starts April 16, so probably not sooner than that right? Not too sure. No specifics have been put out yetAnyone got any insight into actual ship dates yet? Couple weeks away now so presumably shipping dates should start to firm up!?
I have no problem fitting a 210 oneup dropper on my Megatower V2. Why is it so different on the Crestline?Like @PhoS said unless you have a big inseam 180, 210 is going to have too much post sticking out. I’m 5’10 using a pnw loam 175, i liked the silver post, otherwise i generally go oneup 180. I tried to put a 200 transfer on my old bullit and it was a no go. And im on a rh3
Well pre-order shipping email stated early April, so hoping for that! Get warmed up for the Bike Parks this summer!Sea otter starts April 16, so probably not sooner than that right? Not too sure. No specifics have been put out yet
Almost. It will be the Edge for my 181.2. Adjustable travel 150-180 mm.Anyone thinking about a Intend Flash 38? It can be setup up to 190mm and weight 2600g, ~200g over a Fox 38
Check out the 200mm offering from Wolf Tooth. It has a much lower insertion length. I posted about this a few back. Seems to be the best solution for those on an RH3 around 6' tall looking for max riser and being able to get as close as possible to fully slammed. One UP 210 mm insertion length 305 vs 271+ 20.2 (291.2mm) on the Wolf tooth. That's nearly an inch!I had 150 cranks initially, sized up to 160. Still couldn’t run longer than 180 post. The issue is the longer post insertion, if the post insertion length was the same i could run a 200, but when you have the added length on both ends you can’t insert it far enough.
Also full builds available on crestline site![]()
www.wolftoothcomponents.com
after the embargo lifts. Sometime around the second week of April.Anyone got any insight into actual ship dates yet? Couple weeks away now so presumably shipping dates should start to firm up!?
I did notice that. I am hoping this lines up with rumors of higher density batteries coming from DJI.Anyone notice in the new releases he mentions a battery option between 600wh and 800wh, but doesn't (can't) actually say what it is?
The 200mm WT’s insertion length is 21mm longer than the 180 OU according to the specs online.Check out the 200mm offering from Wolf Tooth. It has a much lower insertion length. I posted about this a few back. Seems to be the best solution for those on an RH3 around 6' tall looking for max riser and being able to get as close as possible to fully slammed.
Resolve Dropper Post Tech Specs and Dimensions
Wolf Tooth Resolve Dropper post key metrics and dimensions.External stack height This defines the amount of saddle height that is not usable as travel. Less external stack height allows you to run a longer travel dropper. The external stack height of all Wolf Tooth Resolve dropper posts is 32mm...www.wolftoothcomponents.com
I'm comparing the 210mm vs the 200mm since this will provide the height needed for me. Haven't bothered looking at the 180.The 200mm WT’s insertion length is 21mm longer than the 180 OU according to the specs online.
Gotcha, if you look close at the added 20mm’s for the cable connector, it’s 21mm’s longer from the collar down.I'm comparing the 210mm vs the 200mm since this will provide the height needed for me. Haven't bothered looking at the 180.
The OU 180 has the same insertion length as the WT 200, on second glance.
Its not. I added that and noted it in the math. its checks out . 271+20.2=291.2 vs 305. The WT has a shorter insertion by ~15mm. I am hopeful I can squeeze out a couple more mm with some creative cable routing. I like my seat slammed.Gotcha, if you look close at the added 20mm’s for the cable connector, it’s 21mm’s longer from the collar down.
Yes. Should come with the Spectre framesDoes anyone know if there is a new vivid expected as well at Sea otter?
I would def order it if not having the ‘regular’ ordered already. Looks so sick.View attachment 179423
Well, I drank the Kool-Aid and snuck into the Forged carbon frames they dropped this morning, that color was too sexy to pass up. Will be selling my Forbidden Druid Core come June.
Got in on the forged carbon drop this morning too!View attachment 179423
I’ve been running xx11 speed for years on my ebike, (Bosch cx race) without any issues.I have the same debate, to has coast shifting or not…
Btw I hear the xx 1195 cassette don’t handle ebike torque well…. But would love a short cage derailleur.
Speaking for myself, this isn't "hard" per say but this is my first VPP bike and Ive always been able to put in the right dropper post without thinking about it on all my other bikes- well since droppers were invented at least. I've never bothered to measure my seat height. Having an adequate amount of seat post without too much stack height when lowered is a big deal. Not having the frame makes it hard to see what the stack on a lowered seat is. I thought it would be appropriate to come to a forum where people talk about these type of things and you know, talk about it. It seems that I am not the only one with this question either. But thank you for your helpful contribution to the discussion!this whole dropper length discussion is basically just a math problem everybody that attended school should be able to solve on their own
you know your current saddle height, you know the frame height, the max insertion and the length of the seatpost. why is that a problem for so many?
then ask the right question, all you people ask for is the length and then stating your height. your height has NOTHING to do with that, but your inseam length. 2 peope the same height can have seat heights differer by a more than a few centimeters.Speaking for myself, this isn't "hard" per say but this is my first VPP bike and Ive always been able to put in the right dropper post without thinking about it on all my other bikes- well since droppers were invented at least. I've never bothered to measure my seat height. Having an adequate amount of seat post without too much stack height when lowered is a big deal. Not having the frame makes it hard to see what the stack on a lowered seat is. I thought it would be appropriate to come to a forum where people talk about these type of things and you know, talk about it. It seems that I am not the only one with this question either. But thank you for your helpful contribution to the discussion!
OK - i have 31" inseam. RH3, OneUp V3 180 or 210, math whiz?then ask the right question, all you people ask for is the length and then stating your height. your height has NOTHING to do with that, but your inseam length. 2 peope the same height can have seat heights differer by a more than a few centimeters.
really a bummer, this uncertainity, i hope you are going to cope. if only there was a method to find out for sure, right?I currently have a reverb axs 200mm post I was going to use, but curious if it will be too long for me, sitting 15mm out of the frame. Kind of bummed it won't fit slammed into the frame but oh well.
I know youre being sarcastic, but isnt the info everyone needs right on the website?? Add that with the saddle height on your current rig and you should know what you need.really a bummer, this uncertainity, i hope you are going to cope. if only there was a method to find out for sure, right?
Do people outside of CA get dinged for state sales tax on their Crestie purchase price?
With one of these on order, its also fun to talk about while we wait. However, I get excited when I see a notification for this thread. Then, when I see its another seat post comment, the excitement evaporatesyes, still involves math. and that seems like a huge obstacle for some here. or a lack of spatial imagination
