Pre-order starts next month - Next Crestline Avinox frame set
Trying the fanatik route too here:
Their build total weight = 48.7 lbs
Components listed = 27.51 lbs (totaled parts listed from vendor specs)
(Math would say the RH2) Frame, motor, and battery = 21.19 lbs
However I could not see the battery size listed on the fanatik page for the build?
This puts my Cresty at 45.19 lbs if all is accurate!!
This is why I asked for actual frame weight, sounds too low to be true...
List your build, tires, cassette, wheels, battery size, etc. Also share your shreadsheet. We can all take a guess and whoever gets closest wins your bike!
Sealant adds weight, rotor bolts, cable ties, you'd be surprised...
I will tell you that I've done this game before and the add up method always has came up less than predicted. You are better off taking a known Crestie weight with a similar spec and just swapping the handful of your components to get an accurate weight.
Their is a rumor that the M2 will weigh .3 kgs more btw, to deal with more power. Maybe they swapped nylon gears for steel or the like.
With the 600w battery, trail tires/ wheels, air suspension, the short mechanical dropper that the Crestie requires, 46# is a real possibility.
Heck Cahal just tested a L Mondraker with a CXr, 29er, L, electronic dropper (that's .5# extra right there!) that weighs 46#s.
What build is that? Any build that a cresty is worthy of isn’t going to be 45 lbs lol.
Just for reference, my amflow with WAO carbon wheelset, xo cassette, 170 zeb, ext storia v4, carbon one up bars, DD rear and exo+ front tires is 49.2lbs.
This is the spread sheet build chock full of internet specs and no validation!
Overall this is what I am thinking and trying to convey, it is going to be heavier in reality than the vendors specs I am adding up. Now I really want to weigh everything as I put it together just to see where the discrepancy is.
Your build sounds close to mine (fox 38, WAO, etc), and I am thinking with my RH2 and actual weights for complete builds I have seen I will be around 48-49 pounds.
Just staring at specs and such while I wait for this thing and got a bit confused by specs vs actual total weights.
Overall it is going to be at least roughly 10+% lighter than my 55lb current rig, and this helps me to imagine what its gonna be like while I wait..
It will be awesome no matter what the scale says at this point!! Thanks again for the feedback all. (y)
What’s your parts list look like? I intend to have a lighter weight build on mine as well. A buddy of mine and I currently have the same ebike, but mine is 5 to 7lbs, lighter than his, (but still a durable build) depending on which battery I’m using, (I have both 500w & 750w). And as a result of our bikes weight difference, I get better range than he does, my bike handles much better, brakes quicker and accelerates faster than his. So although some may downplay the weight on an eeb, weight does matter.
Sealant adds weight, rotor bolts, cable tires, you'd be surprised...
Due to popular demand and fear I am tossing Walmart grade goodies on this Crestline to save grams, I will share my 25 lb "all mountain super dh trail enduro" build groupset with vendor weights for reference!!
Totals up to 11,029 grams which = 25.3 lbs. Add this to the 21.1 lb fanatik math and I am getting the 46.4 lb total without a pound or two worth of misc items (cable, screws, etc).
Dont blame me for going shopping now..!!
Nice! Mine is also an RH2 with Berd wheels, (laced to Tune hubs and LB rims with Maxxis rubber) and one up v3 dropper, but 180mm and a 38 or 40 depending on my mood. But I’ll be running XX 11 speed and e-ewing cranks. And like you, I can’t wait!🤘🏻😎
Are you accounting for the shock (and spring)?
Fork is likely 2400 grams+ (they vary).
That rear tire is probably a bit more as I recall.
You are saving a ton on that dropper. Literally my 200mm AXS is nearly a pound more. I did this on my new build due to HCR and hopefully for better function.
Add .5# for sealant. Did you know manufacturers don't include sealant in their weights?
I try to buy the good components that have good weights, however the bike is going to weigh what it's going to weigh in the end to do the job that is intended.
Good points all around guys,
I didnt include the shock and spring specifically above, but I did extrapolate the total weight from a fanatik site build which I assume included the shock, although it was a Rockshox vs Fox.
The Fox fork weight was an estimate as I could not find the actual factory 180 mm X2 damper list weight, so there is likely a bit more in it for sure.
I did not add sealant weight individually either. In my overall spreadsheet I added 500 grams for miscellaneous, so this may be too light of an estimation on my part also.
Thanks all for indulging me with all the great inputs while I wait and wonder about this mysterious bike that will arrive one day. Totally agree overall the bike is more about ride quality for how and where you like to ride vs total weight. Although I'd add that I do find weight contributes to the overall ride and handling character.
Basically I am just sitting here staring at my list of goodies awaiting this thing. Thinking of the weight of my current "classic" emtb at 55lbs vs this upcoming 49~ish lbs and it is almost hard to believe what a difference this is going to make in the ride alone!
I plan to order the RH4 in the March drop and lose 20lbs off my midsection by the time it gets delivered this summer. Not sure why y’all are counting grams on your build 🤣
Just so I can better imagine what this thing is going to feel like when I am riding it.. while I sit and wonder when the heck it will show up!!
GL on your goal (y)
I've got RS181 in RH-2. With 800Wh battery. Spec is with reserved wheels, dh conti tires, cushcore pro front and rear, fox 38/stock vivid, axs 170mm dropper, sram xx drivetrain, e13 helix carbon cranks, enve m7 handlebar, hope gr4 brakes + hope 220/200 rotors. Bike ready to ride, with stamp 7 pedals, front and rear fenders, fidlock waterbottle mount weights 24,5kg/54lbs. I was hoping less, but no way to make it lighter without sacrificing reliability or swaping to 600Wh battery.
This sounds like one hell of a ride for certain!!
Not that there is any need, but if you were "hoping" of course you can make lighter without sacrificing reliability though, heck you can drop almost a pound just changing from the axs to a oneup v3 dropper... Stamp 11 vs 7 pedals, lighter saddle, etc...
I am a bit shocked to see the carbon cranks on there, but sounds super nice! They take a beating ok out there?
MX or 29"? What is your weight, height and inseam?
"... and give you room for a proper dropper..."
I'm pretty sure that the limit on the dropper is the shock tunnel and motor. The taller frames have taller seat tubes, but the dropper can only go down to the same distance from the cranks on all frames. For a given leg length, all that a larger frame gives you is more of the seatpost shaft hidden within the frames seat tube.
Buy a 600 drop 1kg of weight then have the 800/600 combo totalling 1400 per day capacity.... hell with thr fast charger you could be swapping batteries endlessly and keep riding until you die.
Ps ti bolts, lighter pedals, fuck the cush core out of the front an you will pull 500gm out of the bike. Combine that will 1kg battery drop you can get to 23kg.
Can you charge the battery outside of the bike? if you can't it ruins the endless swapping idea and an extra annoyance when you have two dead batteries.
That I dont know. You certainly cant on with Bosch.
I guess even if you wasnt officially possible a sparky could rig it up to charge...
With that said. Do you really need more than 1400hw of capacity in a day? I know im pretty freaken fried when i do a 1000wh day on my bosch with my 400/600 combo.
Heck yeah, I am going for both batteries for my "shape shifter"!
Local bike shop confirmed the hookup when they arrive.. 600wh for maximum fun, 800wh for maximum range days. Both to see if I can outlast them both or die trying!!
Shooting for total weight of 47.5 pounds (RH2, mx), why not?! ;)
RH3, 600wh - 50.3lbs with pedals. I wasn’t going for ultra weight savings but was being relatively conscious about it. Reserve al/hd wheel, zeb, coil, aluminum bars, grid gravity rear tire, grid trail front, xx1 11sp, shmaven brakes.
I could see dropping about 3lbs more with carbon bars, mezzer fork, super deluxe rear and a good carbon wheelset ~15-1600grams. I think 47 ready to ride is pretty realistic, 46 without pedals.
One up (on any cable dropper) have problems on vpp frames. When you slam it down it starts to bend cable and dropper stops working. On my previous sc bullit I changed from one up to axs to get extra 10mm od drop. No problem with high quality carbon cranks.
Is anyone bothered by shorter droppers on these frames? I now run 213mm, but on RH2, the maximum is 175mm.
Thanks for the reply, the cranks sound awesome!
Havent heard of this issue with the Crestline frame specifically, hopefully Troydon got the cable routing down without issue.
I saw the OneUp v3 actually came on the last full e-bike the S180 Classic . Thought that was a good sign:
Anyone having these issues with OneUp droppers on current Crestline's?!! I may be in the return window still if need be.. 🤞
It had me slightly concerned but I think I'll be fine with a 200 v3 on the RH3 after mental mathing it for like an hour.
i like your style.
yeah, dual battery is freaken awesome!
I have a 180mm one up on my rh-2 s180. Check to see which side the cable hole is on. On my s-180 its on the r/h side. I actually positioned the one up post cable stop to the r/h side to match in line with the cable hole in the frame so i could get max insertion depth with minimal cable kink.
    Join 43,278
