what would you recommend for a more confortable/premium saddle? I have comp carbon so Bridge Comp, Hollow Cr-mo rails. It creaks like crazy
Tons of saddle options and it's entirely personal preference.
My favorite is SQ labs 60x 2.1
For creaks, sometimes dripping penetrating oil like triflow takes care of the problem, often times it doesn't
I tore my stock Levo Expert saddle in a fall a week and a half ago. I'm still healing but plan on picking up a Specialized Power Expert with Mirror before I can ride again.
I've had multiple saddles that creaked after a year of torture, now riding an Ergon SM E-Mountain Pro and it's the best one yet. I've had SQ labs (too flat), Specialized Bridge and Phenom (creaked or broke), Ergon SM Enduro Comp (2nd best).
I'm 54 and have ridden bikes my entire life. I don't recall any saddle ever creaking on its own. It has always been remedied by the manipulating the saddle clamp. Weird. Only failures I've had are from bending or tearing them.
I'm older than you and have had multiple saddles develop creaks at the rail/saddle body interface.
It happens. When the saddle is new, sometimes a company will replace it on warranty.
I switched to SQ-Labs
611 carbon . My wife got the 611 reg, it moves with her on switchable durometer bushings. Soft,med,firm. She likes soft.
Mine Is still a mtb saddle but it’s like 200 grams lighter. My dropper is a rocket now!
Comfy enough for the sitting I do🤣its more comfortable than the Mimic, but it’s not softer.
The cool thing is they’ll send you a sit bone measurement packet. In our experience it worked great.
Don’t forget to torque. Seats get a pretty good clamp down.
Oh and no creaks on either saddle
Even the one that moves
Hi guys!
T-Type Sram Cassette issue....
I have 2 set of wheels with gx derailleur and gx cassette 1275 and gx chain....
Rode a lot in turbo on technical climb and i love that 😊
But since i get the gen 4 with 111nm the chain last 500kms before ro be destroyed !!!
And the cassette it is a nightmare the middle cogs ( 4 and 5) bent so easily making the shifting very tricky even more since the last derailleur update.
I am not the only one around with this problem.
On the SRAM website, the cassette 1275 is not rated E-BIKE but the XO 1295 ( the dark one ) yes.
And for sure it is more expensive but is the cassette 1295 more stronger than the xo 1295??
With my previous bike ( race bosch gen 3) i aslo add this troubles but not so offen.
I am a racer guy 80kgs with gear,
Not new to MTB or E MTB, i know how to shift😊
TIA
Hi guys!
TIA
The guys here were only getting about 600k of a chain and cassette when they were testing the s-works before launch.
Not many drive trains are going to withstand 111nm
I also suggest perhaps apply some mechanical sympathy when changing gears. DJI seem to have gotten that part right. Now if only specialized can add that feature to back the power off when changing gears.
Or detune the power to the standard levo. Seem that one is getting much more range out of a cassette and chain.
Then again , if you can afford a s-works you can afford new cassettes every 600km
On all my S works i would have ro replace cassette and chains at around 600 miles. Just over 2k miles on Orignal Amflow one still going strong, the smooth shift really helps. Note on the UNNO they were seeing 4k under testing often used in Turbo mode. Easy to see why so many Brands want this batt and motor setup
Thanks for your NO reply😅, really not constructive at all
I will not lower the power, are u serious😂?
In fact if your bike is factory setup to 111nm, the factory have to provide you strong équipement to suit the power !!!
I am a dentist so in don't care about the money!!
I JUST want to know if the 1295 cassette is stronger than the 1275.
OR IF there is another stronger cassette available somewhere🤷‍♂️
Hi guys!
TIA
I'm sorry but maybe you know how to shift but you're obviously a bit clueless what you're doing. You can't expect to put this torque/power figures on a flimsy bike derailleur drivetrain and not have massive wear and snapped chains etc.
On my comp carbon it is the XS 1270. It is all steel & is very durable (they call it s-series which it is exactly like a GX but heavier less fancy & dedicated for bike manufacturers). I have 1500km of hard riding on it & still well in specs.
Check this video out. He explains everything you need to know about all the SRAM differences for the AXS transmission (s-series, GX, XO, XX). The only drawback it is a HG hub
Thanks 🙏
From my understanding this cassette is only available with HG shimano free wheel design ?
yes that's the drawback, But you can replace gear from 1 to 4 if necessary.
A voir ce qui est plus important pour toi...hub ou tordre chain/cassette
All rings are steel on the HG-1270 and the lowest gear on the XD-1275 is aluminum.
Wouldn't the 1270 HG last a lot longer?
    Join 43,112
