I have a Cube Stereo Hybrid ONE44 HPC with the System Controller and the Purion 400.
What do I need to install the Kiox 400 C?
I know I need the display adapter.
What about the cables? Is it just a case of removing the System Controller, connecting the Kiox 400C, and it will work ?
Do I need to remove the Purion 400 ?
Do I need to change the cables ?
Please explain in simple terms, with the steps and the parts to be changed.
I swapped my Purion for the Kiox not long ago, it’s pretty straightforward.
Remove the system controller from the top tube.
Disconnect the Purion and remove the unit from the bars.
Push the Purion cable through the headset bung (you may need to lift the stem and spacers up to give easier access to this) and simply coil the cable up. I then inserted the cable into a small plastic bag and zip tied it closed to prevent and moisture ingress on the plug end.
Fit the new Kiox on the top tube.
Then on the Flow app remove the Purion from the component list.
Turn on the Kiox and add that to your component list.
This is where it gets/can be a bit tricky. Pair the mini remote with the Kiox (there’s vids online of how you do this, as I can’t remember, sorry).
If the Kiox doesn’t operate once it is paired, then the easiest method I found was to remove the bike from the Flow app and then set up as a new bike. I had to re-install the updates once I’d done this though. Your bike mileage will be unaffected, as it will transfer over to the new Kiox.
Sorry the last bit is a bit of a faff, but that’s what I had to do to get mine to operate.
