Colorado. Big rocks, steep lines, slabs, roots, and it just keeps going and going.I’m still not convinced that the average Levo rider needs more than 150mm (the two I met last weekend had just ridden down the road and had a long fire road climb back to the pub). I know a bunch of people who ride Fod tech and park in the alps on 150mm bikes, where y’all riding that you need more? Sherwood pines? Swinley?
I just put 155mm Hope Bosch Narrows on my Gen4 so they should fit.Anyone knows if the Race face ERA EMTB crank arms will fit the new levo 4?
Era eMTB Crankset | Carbon Crank for e-Bike | Race Face
The Era eMTB crank is a durable carbon e-mountain bike crank designed and built by Race Face. Optimized for Bosch Gen 4 and TQ HPR50 drive units. Lifetime Warranty. Crashes Included.www.raceface.com
I had mine on Monday and have put 60 miles on it , can’t say I’ve heard anything like that , it is very quite, the most comes from the grit and stones hitting the down tube ,Hello from Germany,
Since two weeks I have my Levo 4 Expert Pro frame. It’s great and Motor noise on ride is really quiet like specialized said but on downhills or just Backwheel drops there is a clunky noise from the motor. Even when you slightly pull the chainring back there is the same sound.
Has Someone the same experience?
That’s a real bummer![]()
I had a problem with my GX derailer on my Gen 3 and the shop was nice enough to give me a Gen 4 Expert as a loaner. Brand new and making the same noise you describe. I had the mechanic take it for a quick spin and he agreed it wasn’t normal. Not sure if it will go away after the motor breaks in, maybe 10 miles on it right now. Clunking largely goes away under power.Hello from Germany,
Can you make a video of the noise? Would be helpful to anyone having similar issues to identify and gather more information.Hello from Germany,
I'm not sure I dislike all SRAM brakes, but so far I am not liking the Mavens. They squeak easily and are way too grabby - it's easy to accidentally lock the wheels. Is it possible to change pads?, I’m not a fan of sram brakes and still not
Would like to, but can’t upload itCan you make a video of the noise? Would be helpful to anyone having similar issues to identify and gather more information.
At the Riva del Garda festival I rode the new Levo and didn't hear any rattle from the motor, although on the other side Spesh did have a sample motor on display that had the housing cut of so you could see the internals, turn the gears, rotor etc. When wiggling the main axle back&forth that motor sample had distinct gear backlash happen accompanied with the sound we all know to good.
As I didn't hear any sounds from the bikes I and my friend rode It could be that just some motors are lemons...![]()
YouTube. Unindexed video if you want, share the linkWould like to, but can’t upload it
Your bike is clappedI have a few issues with my g4. Anyone having similar issue?
1) charging port replaced under warranty second week in. When I would plug in fast charger to bike frame it wouldn’t register. Temp workaround was charging battery directly.
2) sworks on the ND side of motor is upside down.
3) my clock on the mastermind doesn’t stay correct. Requires me to connect my phone to bike via app to sync.
4) motor drops power very briefly 3-4 times per ride.
Anyone else having these issues? I have about 370 miles or so on my g4.
Ride mine for the 1st time 2 days ago.I have a few issues with my g4. Anyone having similar issue?
Anyone else having these issues? Ihave about 370 miles or so on my g4.![]()
Same issue here with powerdrops! Have replaced : drive unit, lower batteryholder with powercable and chargingport. Have a new battery also, will test tomorrow.Ride mine for the 1st time 2 days ago.
I have noticed the same "drop power" as you discribed....
I have 2 battery and it seems the "drop power" is a battery issue
With the battery supplied with the bike i can feel the " lack of tork" especially in stip climb!!!
I was really disaponted as i was thinking that is was the way the motor work ...
I did the same lap with my spare battery and it was night and day, and the bike felt strog everywhere and the smile of my face couldn't go....
Me its night and day when i change the batterySame issue here with powerdrops! Have replaced : drive unit, lower batteryholder with powercable and chargingport. Have a new battery also, will test tomorrow.
In every modePowerdrop in which mode? Turbo?
Good to hearMe its night and day when i change the battery![]()
Did you borrow a battery from another Bike or die you buy a extra?Me its night and day when i change the battery![]()
I bought a extra one !!Did you borrow a battery from another Bike or die you buy a extra?
Yes 800wh840wh?
How much?
