Can someone steer me in the right direction here. Trying to set the rear sag on my 2022 Kenevo SL Expert with the Fox X2 Float rear shock.
Following this, origionally I measured the total travel as per the Fox guide.
tech.ridefox.com
Suggested Sag Measurements | |
Travel | 30% Sag |
51mm/ 2.00in | 15mm/ 0.60in |
55mm/ 2.25in | 17mm/ 0.68in |
65mm/ 2.50in | 19mm/ 0.75in |
70mm/ 2.75in | 21mm/ 0.82in |
75mm/ 3.00in | 23mm/ 0.90in |
89mm/ 3.50in | 25mm/ 1.00in |
But after fully letting the air out of the shock. My travel to the bottom of the o-ring comes in at ~60mm.
With roughly 7mm - 8mm space left above the o-ring.
*photo for illustration, I had slightly moved the o-ring before taking the photo.
Based on the technical data sheet, I am assuming that is correct ?
So for setting the rear sag at ~30%, take the measurement from the 60mm (or 62.5mm) rather than the full length as per the fox guide ? So 18mm sag (based on foxes table and my own measurement)?
