Kenevo SL Official 2022 Kenevo SL (KSL) Megathread!
Hello folks. My Gen 1 KSL which is a bit over a year old started having this knocking sound when the motor disengages. So basically motor kicks in, you get the support then when I stop pedaling I feel a knock as the support goes away. More noticeable on full support 100/100, but also noticeable in my trail 70/70 mode. I don't know if I'm just noticing this now and it is normal, or if I should take it to the shop for evaluation.
Any input would be greatly appreciated.
What happens when you pedal backwards???
nothing. the usual nothingness. no resistance, no odd sounds, no engagement of anything.
I only ask because its what I just experienced. When I would pedal backwards it was NOT disengaging and it would also grind when pedaling hard.... had to replace motor.... I think I read somewhere someone had knocking sound on KSL. let me see if I can find it....
Hi, is it normal to have 90% of battery capacity after 80 charging cycles? Quite disappointed with that. Did any of you request a warranty claim?
Anyone in the UK have any experience with the Vivid shock, tuned for the SL?
My LBS says none available in the UK and 5 months wait before Rockshox will have any in country?
Don't know whether to try to import one myself or go for a standard tuned vivid
All thoughts welcome.
Cheers,
John
Cheers,
John
Just get the standard shock and have it tuned with either TF or J-Tech, if you buy it from them they’ll set it up for you. It will probably be better than the “factory” tune anyway.
I was a little bit afraid that the new Levo would make my KSL has been but it is hopefully not that light 😅
Went for a ride this evening, the bike still make me smile!
Anyone got a copy of the dealer software, or know where I might find a copy*? I'd like to be able to flip between mullet and 29 on a whim and my closest friendly LBS is an hour away.
* preferably without having to become a dealer ;)
Planning on swapping out the Code RS for Hope T4V4. Anyone have any tips?? I don't plan to get the vented rotors, in which case, do I still need to swap the stock rotors for hope floating or fixed rotors? If I do end up having to change rotors, i assume I will need hope rotor adaptors right? Thanks!
Progressive spring, needed on these?
Ive just purchased an ext e-storia for my ff kenevo so will be fitting the ohlins ttx22 to the ksl to replace the float x.
Its currently got an mrp 550-670lb progressive spring which seems to work well on the ff, giving 30% sag and no noticeable bottom outs.
Im wondering whether to replace it with a 550 or 575 ohlins spring. (Ok i also like the yellow 😁)
Öhlins has a spring calculator in their web pages. They have specs for KSl. You need to enter your weight and how much sag you want to run.
I have the ttx22 on my ksl, and an e-storia on my other bike.
I wish I could swap them, as I think bottom out control on a coil is required on the KSL. I just want a bit more ramp up/ resistance at the end of the travel.
A progressive spring would probably solve the problem too.
Looking at a leverage graph i found, the ksl looks to be fairly progressive, certainly compared to the kevevo.
Im hoping the hbo of the e-storia will allow the stock ext spring to work on the kevevo.
I thought there may be too much progression on the ksl with a progressive spring as well.
Luckily both shocks are 230x62.5 so i can test on both bikes. Helpfully the mrp and ext spring also have the same ID so are compatible with either shock so i can do some testing before deciding if i need to buy new springs.
Hi all,
I needed to change my dropper post cable and housing yesterday.
I have taped the original housing to the new one but lost it half way in so I pulled the whole thing out and was able to push the new housing back from the head tube to the motor cover and then in the seat tube but I wonder if I might have missed a specific tube in tube routing that way? From the technical manual it was unclear to me if the routing is tube in tube over the battery.
And I have lost an housing end cap in the frame :ROFLMAO:
Thanks !
Hi all,
Thanks !
Its so much easier to whip the motor out. There is a moulded tube in the frame that the gear & dropper cable go through.
The electrical cable just ran next to the battery. Well this is how it was in mine anyway.
Thanks for the info, I might need to whip the motor out to check the cable went through the proper tube and not rubbing somewhere else then...
Not that simple. The sw checks in with Specialized servers....so having the software will do nothing without a working account.
Great upgrade, I hate Codes for longer descents (15miles-30 miles)
Nothing special, use any rotors you want so long as you have the correct post adapter for the diameter.
I like the Vivid Ultimate Coil with Hydraulic Bottom Out. I have my SAG at exactly 30% and no bottom out on jumps or drops.
Can someone steer me in the right direction here. Trying to set the rear sag on my 2022 Kenevo SL Expert with the Fox X2 Float rear shock.
Following this, origionally I measured the total travel as per the Fox guide.
Suggested Sag Measurements​
Travel​
30% Sag​
51mm/ 2.00in​
15mm/ 0.60in​
55mm/ 2.25in​
17mm/ 0.68in​
65mm/ 2.50in​
19mm/ 0.75in​
70mm/ 2.75in​
21mm/ 0.82in​
75mm/ 3.00in​
23mm/ 0.90in​
89mm/ 3.50in​
25mm/ 1.00in​
But after fully letting the air out of the shock. My travel to the bottom of the o-ring comes in at ~60mm.
With roughly 7mm - 8mm space left above the o-ring.
*photo for illustration, I had slightly moved the o-ring before taking the photo.
Based on the technical data sheet, I am assuming that is correct ?
The Fox Float X2 Performance shock used on this model measures 230 x 62.5 mm
So for setting the rear sag at ~30%, take the measurement from the 60mm (or 62.5mm) rather than the full length as per the fox guide ? So 18mm sag (based on foxes table and my own measurement)?
Appreciate, for me I am unlikely to notice 1 - 2mm of sag measurement. But still curious.
Travel​
30% Sag​
51mm/ 2.00in​
15mm/ 0.60in​
55mm/ 2.25in​
17mm/ 0.68in​
65mm/ 2.50in​
19mm/ 0.75in​
70mm/ 2.75in​
21mm/ 0.82in​
75mm/ 3.00in​
23mm/ 0.90in​
89mm/ 3.50in​
25mm/ 1.00in​
Not that much of a difference if you take 18mm SAG (60mm stroke), 18.75mm (62.5mm) or 19.5mm (65mm).
I'd go with the 18.75mm SAG for the 62.5mm Stroke as the specialized data sheet says. If you set your SAG to 18.75mm but the stroke was only 60mm you're still only at 31.25% SAG. So no Problem, unless you're always bottoming out.
    668K
