SZZS CEF50 lightweight using Bafang M820 motor (Specifications Thread)
good morning, a question regarding the chainring: it does come standrd with a 32T, but can I find different size aftermarket? Is it steel? Do we need any special proprietary tool to remove it?
I assembled it with 34T, but I've never disassembled it so I don't know if I'll need any special tools to remove it. I think 32T would be bad for maintaining faster shifting speeds.
I use a 104BCD 32T aluminum aftermarket no prob. Raceface is a common choice. Don't need steel on a 1x12 drivetrain, very little wear and 2-3x heavier.
Should be able to run a 30-36 T range on 104BCD depending on needs.
The only thing about compatibly is the Bafang spider (like Mike's link above) and the ISIS interface/spindle.
Fortunately that's why we have a wide range of cranks to use (ISIS compatible).😁
Thanks for the clarification, it helps.
But you’re correct, crank ‘s length will do the trick (ordered some 155mm from Miranda).
Well, I was thinking of a 30T as it’s pretty steep where I live (and any bike I’ve tried in 29er that uses 32 or bigger always felt off) and the bike will likely never see the asphalt to reach those speeds
    Join 43,273
