Who owns Crestline 180
51 lbs coil front and rear with pedals. Rh2 mx 600w
Good work from Crestline! More manufactuers should take note
One of the main reasons I'm going for crestline. Different battery options. With 400wh i can get close to mid power weight.
I can always turn the motor down and pretend im power hehehehehe.... Then grunt it back up when needed.
Also most of my rides on the pole were sub 50% used with a 750wh. I might as well have a 400hw option and have a lighter bike than be carrying extra capacity and weight most of the time.
Oh yeah,
It was the bike i wanted before the Pole Voima. Now i'm getting an S180. RH-2 MX
Going to do the following to it
Sell the T-Type asx, Maven brakes, DT swiss wheels and vivid air shock.
Replace with XT link glide. Xt brakes, Envy foundation wheels and custom local manufactured coil shock. Handle bar with be changed out to a carbon one up and +5mm headset.
Why do all this buying and selling? Frame only was sold out, so complete build and swap out parts was the only option.
I've spec'd 600wh and will also get a 400wh battery.
I'm looking to get the bike down to 21.5ish kg with the 400wh to get close to mid power weight.
Most of my riding on the Pole was sub 50% battery usage (750wh battery). So I figure i can take that weight savings and run a 400wh for most of my riding. Then on big park days, I'll have the 600wh and be able do a battery swap mid right and get a 1000wh day.
I think I may have got the last RH-2 frame they had, I placed my order and checked back a few hours later and it said they were sold out. There’s a few shops in the US with frames in stock, I know Fanatik has one in each size. If they would have sold out my backup plan was to do exactly what you’re doing, buy the S180 and part out the things I didn’t want.
Are you running 160 or 170mm mode? 51lb 23.2kg is heavier than i expected. Then i look up the push fork and thats 2.8kg So 500gram heavier than the zeb and the coil shock will be a similar heavyness. Are you running DD or exo casings?
PS How does the push fork perform? Also why not run a push in the back too?
I looked at resellers to supply the frame only. But they had 800hw battery option which i don't want and didn't offer shipping to NZ. Plus i preferred to purchase directly from Troydon for any possible warrantee issue's that may occur. Then i would be dealing directly with the owner.
170 fork / 160 frame. I'm not a heavy guy (155 geared). Weight is pretty much what I expected. The LS160 spec is listed roughly at 48lbs and adding coil to the fork and shock is an extra 2lbs. WAO convergence wheels aren't light either. DD rear and EXO+ front.
I love the push fork, tracks well, plush, and decently poppy (less than a 36 but better than a 38). Unfortunately, push doesn't make an 11.6 tune and some guys on the facebook page have noted the 11.6 doesn't fit the shock tunnel.
SV8 will fit but it is a generic tune and I would need my suspension guy to tune the shock. Troydon had vivid coil's already tuned for the crestline and was able to give me good deal. I'm a big push fan boy but from past experience the Vivid/SDU coil is an excellent coil shock for the money. Plus the red coil is a nice touch to the matching cascade link.
If you want a push like coil check out these custom suspension builders in nz.
$1700nzd. Norm tells me he has made and tunes them for crestlines before.
One thing to note about the 400wh battery is you won't get max power. Troyden said it's great for bike park days where you need minimal assist but it won't work for blasting shorter turbo rides.
New Crestline S180 is finished, just completed all upgrades. 1st ride this weekend. Hope she rides as well as she looks! @Rob Rides EMTB wanted to thank you for all the information and inspiration! Your videos and insight was a major factor in choosing the bike. Will definitely compliment my Orbea Wild and YT Decoy.
Bike Specs after upgrades:
Crestline S 180 Classic Edition 2025 -
Bosch CS Gen 5 Motor, 800WH Battery
Frame: Crestline Carbon LS 180 frame (180mm rear travel)
Rear Shock: RockShox Vivid Coil Ultimate RC2T 230x65 mm
Fork: Rockshox Zeb Ultimate 180mm
Headset: Works Components Reach Adjust Stem: Industry Nine A318 - 40mm (Red/Black)
Bars: SQlab 3Ox12deg Alloy (45mm Rise, 31.8 x 780mm)
Grips: Rev Grips Pro Series Black/Red Anodize
Seat Post: Rockshox Reverb AXS 170mm x 31.6
Saddle: Ergon SM Enduro Comp
Brakes: SHIRGURA (Shimano Saint Brake Levers/Magura MT7 Calipers) Front Pad - Sport (green)/Rear Pad - Performance (grey)
Front Rotor: Magura MDR-P 220mm
Rear Rotor: Magura MDR-P 203mm
Wheelset: Industry Nine Hydra 2 Enduro
Custom Black/Red spoke pattern
Front Tire: Schwalbe Magic Mary 29x2.6
Rear Tire: Schwalbe Big Betty 27.5x 2.6
Cranks: SRAM X0 Eagle Transmission 160mm ISIS - Black
Chainring: SRAM GX Transmission
Chain: Sram XO T-Type Eagle, 12s, Powerlock
Cassette: SRAM XO Transmission
Rear Derrailleur: SRAM XO Transmission AXS
Shifter: SRAM Transmission
Motor: Bosch CX Drive Unit - BES3 wireless remote/750W-100nm
Battery: Bosch Powertube 800Wh
20250529_133042.jpg 20250529_133050.jpg 20250529_133057.jpg 20250529_133103.jpg 20250529_133116.jpg 20250529_133130.jpg 20250529_133204.jpg 20250529_133159.jpg 20250529_133145.jpg 20250529_133215.jpg 20250529_133223.jpg 20250529_133232.jpg 20250529_133256.jpg 20250529_133301.jpg 20250529_133304.jpg
View attachment 161521 View attachment 161522 View attachment 161523 View attachment 161524 View attachment 161525 View attachment 161526 View attachment 161527 View attachment 161528 View attachment 161529 View attachment 161530 View attachment 161531 View attachment 161532 View attachment 161533 View attachment 161534 View attachment 161535
Beautiful! What size is your bike? Can you slam your axs reverb?
Congrats you literally own one of best E bikes on the planet.
Enjoy
Real nice photos and build. What's the all in weight?
Now go out and ride it like you stole it!
PS have you somehow got the 100nw 750wh upgrade already? i thought it was released in July.
I haven't weighed bike yet. Will update you over weekend. Need to see what specs motor is. Not sure if it's loaded with new software update.
The last set of posts about this already got deleted, I recommend you delete yours and read the instructions in the email.
I saw that last week.
But after I saw Rob posting about it and various others reposting his post I thought the word had gotten out and it was ok.
No worties I deleted and I guess you should remove my quote from your post as well.
Did you see Rob’s post or was that deleted as well?
I didn't see anything but didn't go looking. Sucks people can't keep their mouths shut but I know it's all about the clicks :P
I didn't see anything but didn't go looking. Sucks people can't keep their mouths shut but I know it's all about the clicks :p
I figured if Rob was posting and it was all over Facebook on Sunday he had Troydon’s blessing
I posted it for one reason because it’s exciting.
I don’t care about clicks lol
Sorry that was directed at Rob, not you. I'm sure he had Troydon's blessing insomuch as Troydan had to give up keeping to on the down low anyway...
Can someone tell me where to find the serial number on my S180? Need it for insurance purposes but can’t find it.
    Join 43,159
