slartibartfast
A few updates and clarifications that I have learned from my DVO Jade X install:
I am 170lbs out of the shower. I went with the 475-550 progressive spring. With XC style gear (half shell, knee pads, water bottle) I get 27% sag. With enduro gear (full face, chest protector, knee pads, backpack with a liter of water) I get 30% sag. So, I am the rare and lucky rider who ended up with a spring that is perfect.
- The comments above about trimming hardware now make sense. Fox and DVO shocks use IGUS bushings, but RockShox shocks use DU bushings. So, the people trimming are actually cutting the IGUS bushings to make them flat to the eyelet. I suppose that works, but the correct method is to pop out the IGUS bushings that come with the Fox or DVO shock and then press in DU bushes. The press for the DU bushes is cheap, and the bushes are a wear item, so my advice is to buy the press and use DU bushes.
- See this GREAT write up from The Lost Co for all the gory details: A Complete Guide To MTB Rear Shock Mounting Hardware
- I used new shock hardware from Offset Bushings, but now that I better understand how this all works, the stock hardware would have been fine. Shock Bushings | Trek Rail
- While I didn't need to order these, they are made from higher quality materials, and I don't mind having some spare parts.
- The advantage of the stock hardware is it has an O-ring side that goes against the shock eyelet. The Offset Bushing hardware does not.
- Not sure how much of a difference this makes. Mud is rare for me, so I suspect it's a non-issue.
- I also ordered my DU bushing press from Offset Bushings. It worked great.
- When new, the DVO shock shaft didn't want to spin. But, after mounting and cycling the shock to confirm it clears, the shaft rotated so I could put the rebound knob on the back.
