Bafang Go+, is it a new App for all motors ?
Hello mate.
Many thanks for a review.
Yes, with Go+ are still some issues. Important is also to have fw 1.2. (Some users experience proper connectivity also over different firmware versions)
So you set to 0% and assistance is gone? Truth say, I have never tried this. In Besst there is lowest value 1%.
Good to know.
I am pretty confident it was 0% but it's possible it interpreted 0 as 1, I was doing all the work and making all the noise while the motor silently slept.
Hello
I have connected the Bafang GO+
application to my bike and I get what is seen in the following photos in the configuration of the different levels.
As you can see how it is configured (I haven't set it that way, it's how it appears when you connect it). Would you change something?
Screenshot_2024-08-21-19-25-48-240_com.bafangen.ride.jpg Screenshot_2024-08-21-19-25-58-532_com.bafangen.ride.jpg Screenshot_2024-08-21-19-26-04-446_com.bafangen.ride.jpg Screenshot_2024-08-21-19-26-09-529_com.bafangen.ride.jpg Screenshot_2024-08-21-19-26-19-500_com.bafangen.ride.jpg
New Bafang Go+ v 3.1.0 has not improved at all. It allows startup angle to be set between 5'-15'
The older v 3.0.0 was 7'-180'. Weird 🤔
hallo bafang what's going on?
15 degree could be not enough for some...
Omg.
Thanks! Can I assume that lower settings will save the battery? and higher will have higher consumption?
Acceleration will have a small effect on battery consumption where max power has a much bigger effect. Once the motor is ramped up it will consume the same amount of power regardless of the acceleration setting.
I run my acceleration at the maximum setting. If at the maximum setting you feel like the motor kicks in too harshly (surges) you can adjust the setting down to your liking. Surging is not a problem I have with the m820, perhaps because my other emtb has 3 times the power and I'm used to it.
Having said all of that I haven't done exhaustive testing on this. I am basing this on my understanding of how the settings affect the power during a ride. Perhaps others will weigh in.
Hola tengo una duda, se pueden ver en el display los watts, que indican el consumo o la ayuda que nos da el motor, o es lo mismo?
Gracias y un cordial saludo.
You can view in the app in vehicle information it gives you a voltage readout. It is not possible on the display.
I tested the development version which had several bugs.
Reported them, so they hopefully fixed them.
Haven't bothered with it since though.
Seems like they scrapped the Bafang Go + app and now I can see only the new Bafang Go app. Hopefully it will allow easier change of parameters. We have Strava sync feature). I wish for speed unlock now )
Ou, they still messing with that apps. ;)) Speed unlock wont be there, cant be due to laws.
I update yesterday Bafang Go app on my Iphone and I have a error message with my M820 motor. Material is not compatible.
do you have a solution? before this update no issue to connect
Which display you have ?
The new app can read data from v 2.0. But it can't edit the assistant levels it's says success when I try to write but it is not getting saved.
delete apps you have. Download v 2.2.0 install pair with bike and you will get the changes you want
