What did you do to your EBike this week?
Someone's thrown up Lucozade all over it.
Only joking.
I thought it was blood 🩸.
Not joking 🙃
Replaced my lads handlebars with some Burget High Rise 38 after cutting them down to 780
Replaced his pedals with some One Up Aluminium ones
Replaced his tubeles valves with Peatys
Fitted the Mango Peaty's accessory kit to my valves
Updated the Bosch firmware
Got some new inserts as the red nail varnish ones looked terrible when I took the last pictures.
The 2025 SDLX ULT is pretty damn good already but I'm betting the new can will make it super kush. 🤞
The RockShox Linear XL Air Can Upgrade Kit increases the positive air volume of your 2023+ Super Deluxe Air shock, giving it a more supple initial stroke and making it a "Mini Vivid". With a more linear feel, your Super Deluxe gains a more coil-like initial stroke but retains the progressive air shock end stroke that we love!
Thats only to take a picture for demonstration… but if that eventually happens I will use the same tool to put the rotor back in shape 😂
I've been looking at it the last six weeks while in hospital with the wife as she suffered a massive stroke
I Hope she gets better soon.
Today was my first ride after three weeks of rest fron a pacemaker implant. A year and a half ago I went through an open chest heart surgery also. Trust you’ll all be back home soon 🙏
Not as exciting as some of the replies but I do love a bargain .picked up this neat little bike tool kit in Lidl, cracking quality and works a treat, £9! Been looking for a small ratchet to put in my waist pack. But refused to pay £30 odd quid for Topeak etc. problem solved!!!
I rode it though a fence!
Doing my usual weekend morning loop (22-30km, depending on the route), I suddenly discovered that my neighbour had stretched a fence for her horses across the road to her farm
If I had ridden the same road uphill, I had of course discovered it, and at a low speed. The problem was that I entered the road from a trail, and just set off downhill. There, the fence appeared right in front of me! I tried to brake, but was unable to stop before I tore both fence wires off.
Luckily, it was white nylon (or similar) with thin electrical wires wowen in. It would have been much worse if it had been the thicker iron wire they use around here for cows.
No harm done, I just mended the fence and rode home
I rode mine after checking tire pressure, lubed the chain, adjusted and greased up the dropper and also sanded the pads /rotors again because they had an andozied coating on it that came off. Which I knew was going to make the brakes squeal till it came off. They look great on the bike though. :cool:
Not as exciting as some of the replies but I do love a bargain .picked up this neat little bike tool kit in Lidl, cracking quality and works a treat, £9! Been looking for a small ratchet to put in my waist pack. But refused to pay £30 odd quid for Topeak etc. problem solved!!!View attachment 143817
That reminds me, I wanted to go to LIDL yesterday. They have loads of bike accessory on offer atm. Among others, a bikestand for € 25. Can't do much wrong for that price, can you?
Fitted Chipolo One Points to our Trek Rails.
I got mine through tagged, I like the chipolo but am not sure about tagged overall as I had to take the foam out and then its loose on the seat rails?
You were lucky that the electric fence wasn't turned on! It wouldn't have killed you but it is unpleasant.
The chain began skipping when putting pressure on the cranks but only in the smallest rear cog.
It even did it when on the workstand and I pedalled by hand. What could it be?
  • I gave the bike a good clean and removed bits of grass from the cassette and the jockey wheels.
  • The 12-speed cassette is quite new, has some signs of wear but none at all on the cog in question.
  • The chain is also relatively new and is at 0.13% extension (measured over 100 links).
  • The mech hanger alignment is perfect; at less than 1mm all over the rim vs the target less than 4mm.
  • The shifting remains silky smooth up and down the cassette.
Anyway, once I'd put the bike back together again, the problem had gone! :):unsure:
I can't be that lucky, surely. Unless it was the grass? :unsure:
What else could it have been?
Its probably worn, even if does not appear to be, luckly they are sold in separate so you can buy only that sprocket and keep the cassete.
Too obvious on the seat rails, especially with seat rail kits being sold on eBay. Put ours somewhere really sneaky.
