Okay, I understand a little better now, and you do have some experience in the world of cycling, so your personal reasoning seems sound to me. It's true that if having a throttle is essential for you, the M560 seems like a better choice.
And regarding the battery for your usage, I think you're right to opt for a larger battery.
Yes, perhaps I got a bit carried away with 28 kg, but what I meant by that is that it won't be feather-light. When I mentioned this weight, it's because in my mind, it went like this:
My bike 23kg
Difference between LCE971 and E82 frame +500g?
Motor +400g
Battery +800g
FOX 38 +300g
Float X2 +200g
DH tire + 700g
Panzer + 220g
Sealant + 200g
Total: 26.3kg
And for this weight, it's still concerning my bike, which has been optimized for weight, with all titanium screws, lightweight axles, custom cables, titanium saddle, carbon wheels, carbon handlebars... That's why I said around 28 kg.
As for routing cables through the headset, if it's done properly by the person doing the assembly, it's very neat and functional. I saw someone on the threads
E82 Dengfu frame now available
complaining that turning the handlebars changed gears, but that's simply because they didn't route the cables correctly.
And yes, Camelback (the EVOC bags are fantastic), I also use it very often. I sometimes use a water bottle, but only for short rides.
Thanks for the link; I wasn't aware that there was good progress on the M560. I'll keep an eye on that; it interests me. It might be worth being patient and waiting for the release of this motor.
I can't provide feedback on the new Charger 3 charger regarding the forks, but I do have the Super Deluxe Ultimate
So I've only ridden 150km with this shock, and for now, I can say it does its job. I'm still in the tuning phase, but from what I can tell, it seems to have good progression with good sensitivity at the beginning of the stroke. You have to consider the frame's kinematics as well. So there might still be a slight difference in behavior depending on the frame and especially the settings.
And it's true that RockShox is much easier to use than Fox... When I look at the settings on my Fox 36, it's like a maze.
And based on what you're describing about your riding style, I'm not sure if you really need a Zeb. I think a Lyrik could suit you; however, if you go for an E82 with 170mm of rear travel, you won't be able to have 150mm or 160mm upfront. You'll need a longer yoke and reduce the rear travel. But again, based on how you describe your riding style, I don't think it would be a problem whether you're at 150 or 160mm of travel.
Yeah throttle is mandatory for my enjoyment as I see it. But I'm not sure yet if I should choose m560 500w or 750w
I think smaller battery could be fine but the bigger one 100% sure will. That's basically my reasoning. As well as that as battery ages it loses capacity.
Yeah those weights make sense. But what is Panzer?
Yeah I can see the headset cableling working but if you get it done perfectly the only(?) benefit is cleaner cockpit look. Alot for risks and work just to achieve that. Especially in my use when I have to remove the battery everytime I'm not riding it (during work day and general storage in my appartment with other neighbors). That's why I prefer the holes near headset.
Yeah, I don't see benefit for me in Fox's more complicated settings since I don't have the skills to enjoy those features and even if I did they offer no benefit to me in my riding where as simpler self maintenance is a massive bonus and saves alot of money in a long run.
Yes, I agree. 150/150 travel would most likely work for me but if my hobby continues to progress like it has I fear I will soon regret of not getting the 170 Zeb. On top of that the E82 has softer headtube angle and the bigger battery. So basically in my current opinion the E82 is more future proof for my use even if not ideal for current use. If the LCE971 had possibility for bigger battery I think I would choose it. Though saving about 1,5kg with that frame and smaller battery is very tempting
Could you explain why yoke wears shock out faster? Does the force during travel of the shock come weighted on one side and that wears the shock out faster than normally?
Edit: I checked my battery and it's 840wh. 48v 17,5Ah. The LCE971 battery is 720Wh. 120wh less than my current battery and E82 battery is 1008Wh.
