interestingly just found that the 150 BX dropper post is too long in the medium frame if you are 5'10 such as myself - I wouldn't go quite low enough to be comfortable on - I assume this would be the same on a large frame?
Are there any 150mm dropper posts with a shorter base?
This threads kinda of gone full circle, as we are now having the same conversations we had when those of us who got the bike last year started poking around it properly.
Nah its good to go over stuff again because there's definitely stuff that we all thought that we will have changed opinions on over the last year
shit, 2 teeth missing is not good, sounds like you got some alignment issues, but even then to sheer off teeth is bad! I presume you arent shifting under power? That won’t help. Either way you need a new cassetteI have recently got my E-Summet 19 and I love it. Just looking over it today have after my first ride the other day, and have noticed that i am missing 2 teeth from the cassette one from each of the lowest gears. What causes this? I do not remember it jumping or anything.
Check the original cassette was tight as well, mine was looseHave ordered a new cassette, There is a chance I was shifting under power as was getting used to it. Lesson learnt![]()
Did you not call Wiggle/CRC first? They'd replace that under warranty surely. I'd certainly not expect a cassette to fail so soon.
Watched that last night - great video.
I didn't know that they offered it with this option. I thought that he was referring to the E7000 switch, but then I noticed that the display is different.Interesting that he's using the e7000 motor model, which I would reckon has more range due to lower torque
Got a picture of this?and have noticed that i am missing 2 teeth from the cassette one from each of the lowest gears
BTW, the display indicated 50.1 km. It seems to over read by +/- 6% compared to rides logged on my Garmin Fenix 5. Anyone else getting this result? Is there anyway to adjust it?
Are you sure you've not "just" noticed the lower tooth height designed in to a Shimano HG sprocket to aid upshifting?
there should be 4 of them on the 46t sprocket and on the 37T there aren't shorter teeth but the tooth profile changes.
That is broken tooth’s for sure, how does the chain looks like as there must have been supplied a lot of force to do that damage?Just had a look and I'm pretty sure that its not the shorter ones.
Thank you RocketMagnet, it does make some sense. I have my Fenix set to 1 second polling and thought that this would provide an accurate report of my rides. I think I will log a few rides with my Fenix and use my iPhone to log the rides directly in Strava and compare them to each other. Anyway, I am happy with the range that I am getting and bloody love the bike.
418 Wh battery?
Yeah. They're broken teeth. Both alu sprockets. Which cassette is it? Slx only has one alu sprocket. TBH I'd prefer none!Just had a look and I'm pretty sure that its not the shorter ones.
Okay, that's good news! ?No, the 2019 e-sommet with the E7000 motor comes with the E8010 504wh battery supplied with all the other e=sommets.
Karsten
