Full Face - When do you decide to wear one?
CrispyDesigns
I'm wondering when I should be wearing a Full Face lid as opposed to a normal Open Face helmet?
I have a couple of planned trips to the Alps and have a niggling thought that A full face would be the better option.
When do you guys decide to wear your Full Face?
Cheers
Crispy
Solution
I use an open face helmet for XC rides that dont involve any big descents or jumps etc. Otherwise I wear a full face. I have 2 full face helmets. My main full face is a Smith but that can get a bit hot in the summer so then I wear a MET which is lighter and has more vents. As a bove I sometimes even wear a full face on XC rides in the winter because it is so much warmer. The same criterea applies to choosing between glasses and goggles..........goggles not only provide much better protection but in colder weather stops that cold wind making my eyes water.
Since discovering the fox proframe is as light and well ventilated as an open face helmet I'll wear it for any ride out.
I live in the alps and wear a Fox Dropframe every ride, essentially a full face level of protection without the chin guard.
I have a Fox proframe also which I have to wear when I compete, and sometimes wear at the bike park, but I don't feel any safer and find it a lot less comfortable.
I wear a Bell Super 3, without the optional click on chin guard because I already had a full-face helmet when I bought the Bell Super. My grandson grew out of his full-face helmet; he also had a Bell Super 3, so I bought him the chin guard for it because I couldn't get a replacement full face in time for his birthday. I thought he might turn his nose up at it but he thought it was fantastic! He can ride with his mates to their local trail then clip on the chin guard. He has been using bike helmets since he was old enough to sit on a bike, so it is automatic for him to wear one. He wears one even when all his mates won't/don't /can't wear one and take the piss out of him. Well, they used to do but they no longer do so. They have all learned!
How does it give you full face level protection if there's no chin guard?
I don't find the full face to be much of an issue on an ebike. On a normal bike, it's hot and I usually pull it off on the climbs. On an ebike, the climbs are so much quicker, you are pretty much at the top by the time it's starting to get annoying. Only ebike ride I do now where I pull the helmet off while climbing is a 3000' climb on service roads that is steep as hell and has no downhill traffic.
Riding up a trail without a helmet does kind of suck with the normal bike if it's a bi-directional trail where somebody coming down can smash into you. If the trail is mellow and I have the chance of getting ran into going up, that's when I use the open face or just suffer a bit extra with the full face on during the climb.
1) The dropframe sits much lower, protecting the lower back of the head and ears (areas I have impacted in the past). You feel noticeably more "encased" than other trail helmets I have owned.
2) It does not use any strap/boa garbage to stay on your head, you use the fact that it wraps around your entire head + pads to have a much more secure connection.
3) It is considerably thicker than all my previous trail helmets, as such I would consider it to have more material to cushion an impact. A quick google suggests it weighs 500g vs most trail helmets weighing 350-400g. My wife's road helmet looks like a cereal box compared to it.
I wear a Fox Proframe when it is a bit chilly out or if I know I am going to a place where the risks are higher. Otherwise I wear a Dropframe or a Speedframe. On cold winter rides, I wear a full face MX helmet.
...I've decided that on extreme heat, it's preferable to stay cool (coolder), rather than having protection that will cause disconfort, leading to decrease attention and concentration.
Although protection minimizes certain risks in a crash, it also increases the chance to occur if it leaves you hot, sweating all over the place, and being difficult to concentrate.
I ride/race enduro moto. also. I wear everything available for protection. Even a neck brace. It's a pain to don all this gear. Plus the added weight. And, of course, the heat in the summer. And Mother Nature still manages to find the chink in my armor now and again.
It seems the fastest guys wear the bare minimum for protective gear. So...you may have a valid point that more gear may not always be the best answer for not getting yourself hurt, or for having the confidence to ride faster.
The only protection I wear ALL the time, while riding in group, is the chest protector!
I stopped wearing neck protector (LEAT), since it limited (by a lot) head rotation.
Yes, I'm aware of all problems that can happen in a crash, but, if I want to continue ride for more time, I need to decrease the PACE, and stay in the comfort zone
Too many bolts, wire and implants already! No need for more
That's the hard part. Backing off the pace. And that can also result in crashes. Too much caution can bite you also sometimes.
I've been lucky in my 45+ years of riding and racing. Broke my tib/fib on a casual ride due to a rock that was hidden by some ferns. Caught my lower leg between the rock and the footpeg. Freak accident. No gear would have changed the outcome.
The only other memorable wreck in all of those years was really bad. And it wasn't too long ago. But I "walked away". I think my gear (at least my helmet) kept it from involving doctors (or worse).
I sent it down some very steep, stepped, rock ledges (which I had done dozens of times) and ate it hard so fast that I don't really know what happened.
My buddies caught up and saw the mess and me on the ground. I got up and couldn't quite get my balance (even after 5-10 minutes of sitting down and "taking stock"). We were still on a steep hill but I was the only one that was uncomfortable with standing.
I limped me and my trusty Gas Gas home the easy way and took it easy for a few days under the assumption that I may have a concussion. I had some pretty colors appear on several parts of my body for a while but I was, otherwise, fine. YMMV. lol
On that note....if your helmet takes any type of hit, replace it. It may look fine but it has done it's job and is very likely compromised and no longer up to the task.
Re convertibles - I remove my chin piece when I have no other option. Usually halfway up heart attack hill , just before my brain explodes from hypercapnia , or just after the chest pain kicks in. I really should buy a dedicated full face so I'm forced to stop ......
Last week, we arrived in the Alps and discovered my son had left his full face behind. I was only able to source an open face ,so handed him my lid and I rode the first day exposed. It was an insight into the risks we perceive - I was baulking at blue runs!
I wear a Fox Proframe RS. It’s that light and airy it feels like I am wearing an open face. I have seen people riding pretty featureless & mellow trails come off in unexpected places and have an enormous amount of damage to the face. No reason not to wear a full face with the advancements in technology.
I think it's in the name 'full face'. The helmet you describe provides non of that😂.
The pain/hassle of smashed teeth/broken jaw/broken nose etc just isn't worth not wearing a full face especially the light well ventilated ones.
In my opinion anyway.
I agree. The Fox Dropframe is a weird helmet in my opinion. Just sits mid way between a Trail lid and a Full Face but doesn't seem to protect anything extra than your ears...the things that are potentially lowest on my list of things to protect on my head
  • Agree
Reactions: Dax
I mean obviously I'm not saying, and never said, it is a full face :ROFLMAO:
I'm saying it feels significantly more safe than trail helmets I have owned before. Because of the weight, coverage and thickness, I feel as safe as if I were wearing a full face. I wear it to the bike park, hit road gap sized jumps in it etc, I would not do that with any of my older trail helmets.
For context, I should disclose that I also don't wear any other protection (unless competing), I stopped wearing knee pads a few years ago and havn't had to regret it so far.
Well said @Mario Antony, much clearer and explicit than my points above which I should have said: I am not saying don't wear protection, I'm just trying to explain why I use a certain level of protection that I feel safe in without requiring more. For reference, in 15 years of DH and Enduro competitions, I have had a broken arm, collarbone, sprained ankle, a bad lower back impact and one probable concussion. Bad stuff does happen.
Personally it's about risk tolerance and risk/reward. Having heard enough stories of confident skilled riders just having a momentary lapse in concentration or making a simple mistake even on basic trails - teeth, elbows and knees seem to be the most commonly injured yet easy to protect with the least amount of hassle.
You're not going to protect against everything but if you can cover 95% of events easily then it makes sense.
I'd have to agree, I wore my IXS Trigger FF all day in the stifling heat of a Morzine summer and it seemed no more hot/bulky/heavy than my Fox Speedframe. These modern FF lids like the Trigger and Proframe are simply amazing and so light. In true Dad-speak, there really is no excuse for not wearing a FF all the time tbh.
but......I do feel like a tit wearing one in the woods/on trails in the UK so I usually reach for the Speedframe..
Bought an IXS trigger for gnarlier rides and solo stuff. But it’s so light and well ventilated that I wear it all the time now. Truly no reason not to 🤙
Crispy, I had a crash, in a trail full of "baby heads", and resulted in hiting with my neck behind the left ear....
I was a bit confused, and some friends were checking me, and all were a bit suprised to see scars in that region.
So, the Dropframe protects your head further than an open lead, but without the extra bulk/weight/limitation as a full face helmet.
PS: on motorcycle, I really enjoy my Trials (open face) helmet to ride slow on trails (like exploring, or just that casual ride on the dirt) and ride around town for example.
It's airy and less "agressive" riding around town. I must say, I feel a great diference on other drivers and pedestrians, between riding the full face (dirt or road) helmet, and riding with the open lead
@Mario Antony I’m not knocking the Dropframe. If it works for you that’s all that counts. I think personally if I already rode wearing the Dropframe (I currently wear a Fox Speedframe Pro) I think I’d have posted this forum thread as I’d still be considering a full face.
  • Like
Reactions: Dax
True. But there is a huge difference between stupid fast (giving all, unil you almost lose control), and just fast.
What I noticed a while back, is that my big crashs have a padron and are related to being tired (hard week at work + not sleeping well), and not sleeping well the night before the ride.
Even going aware of it... and being careful.
So, presently, I basically prefer not to ride.
I think being tired is worst than being drunk
Sorry for the offtopic
Mario if I waited until I had a good sleep before I rode I would be waiting until I was in a casket ! Seriously though, knowing one's limitations and sticking to it is a key to surviving. Wish I could do it 😉 I don't know about you but when you have been going FAST on any kind of wheels for a long time, going slowwwww just seems unnatural and no matter how hard one tries the speed just seems to happen before you even notice it !! 🤤
cheers 😎
Bwahahaha! You English guys crack me up with your colorful... no... colourful language. I need to incorporate more of your sayings into my daily conversation. I'm afraid, though, that if I called someone a tit, my fellow Yanks would look at me as if I'm the tit. Anyway, you're right about the ventilation of some full-face helmets. In one particular area, the mountains block the coastal flow, and humidity and moisture are a little higher. When the temperatures are just right, fogging of my glasses is a huge problem when wearing my half-shell. Sometimes I just have to pull the glasses down and look over the tops. It's bloody annoying (Bloody annoying? See what I did there?). Since switching to my Troy Lee Stage, the air is forced into the opening, around my glasses, and fogging is no longer a problem. It's counterintuitive, but it's true.
It depends...You still can have fun, without being overboard.
Last time I crashed heavy, was away from the sport, for nearly 2 years, resulted in some surgeries, and ended up with iron and bolts permanently.
That was +10years ago.
Since then, I don't want to repeat the experience, so just ride as flow as possible, and have fun (and sometimes it's plenty fast, as per strava - making the top 10 in some trails, it's worth what it is... couldn't care less!)
The real question here, is:
Are you still proving to anyone, anything?
Absolutely not , but it's still fun as hell. I remember a mx riding course I took , the instructor said "it's inevitable that your going to crash in muddy conditions, you can do it slow and lose or you can go fast and win or maybe crash badly but that's racing "!
It's so fun even if it's just against yourself. and the flow , omg I love slipping into that grove it's like a drug it feels sooo good ! cheers 😎
Cheers
Crispy
Usually when the rules of a bike park dictate that you should for your own safety.
I use a Bell with removable chin piece. Always put it on for any downhill trails and off for riding up. It has saved my face several times over the past few years.
Cheers
Crispy
High Rock Ruti
I've never been able to accurately predict my crashes, they seem to always happen at the worst times.
Seriously though; four face plants in 2023, had to replace the visor 3 times on the carbon rampage pro's.
Warm Regards Ruti
  • Agree
Reactions: Dax
    Join 43,172
