View attachment 115951View attachment 115950
It's an XL set up mullet (ordered as a 29er) I've slapped a few of my parts on. I'll probably leave the rear 160mm travel shock and for geo reasons I used my 160mm fork as I wanted it a hair steeper.
It's at 43#s on the dot with pedals, dual inserts, rear 2.5 DD tire, 210mm dropper, cage & shockwiz. I did check 2 weights while putting it together. My front wheel assembly was the big weight saver as even with a proper tire/ rotor/ good cf wheel/ insert, my entire front wheel assembly was 600 grams lighter than stock. My rear Downhill cf 27.5" rear wheel with a DD 2.5 tire and XTR cassette was only 100 grams lighter than the stock 29er wheel with a GX cassette. I used my OneUp bars, my front TS brake & my preferred seat which is heavier than stock.
I'll probably add my rear TS brake tomorrow (saves a bit), and add my tools (adds a bit) and end up about the same.
Didn't realize that you couldn't multi-shift with a turd GX shifter so I'll get that swapped when I get time to mess with it this week.
I wish it had an X01 11 speed, I used an old HG+ XTR 12 speed cassette I had and I swear I'll never use the first 2 gears.
Also would like 170 cranks, but can't find any. It's also doubtful I'd still be able to fit the 210mm dropper with longer cranks as it's that close and I'm only 5'11" (yes I know, I like my bikes big).
I always run clipless but decided to start with some flats, just to try it out.
Have ridden it just on a little dirt path by my home and it feels like the best geo I've ever ridden as far as fit goes. It's got a really steep sta (real world steep), nice and short from the seat to the bars, but long while standing. BB is nice and high comparatively in the real world, with the 160 Mezzer fork (bit longer A2C than a Fox 36) and the 2.5 rear tire I used (all intentional). HTA measures 63.8' as the bike sits. Love all this so far.
The motor is quiet and has nice assistance, although I have practically no e-bike experience so what do I know. It's certainly plenty for me.
My battery was in super tight, which is a good thing I'm thinking. When I finally got it out, it was a 2 handed affair.
I moved the controller further in just because I have little need to reach it while riding and I think it'll work better for my final controls set up.
Pretty stoked so far.
