It's 200wh, exactly half of the main battery, so likely the same cells.the extender are the new panasonics as well? hopefully not a carryover from last year if they're not available yet.
How long did you have to wait for your bike?
Bike is in stock in So Calthe extender are the new panasonics as well? hopefully not a carryover from last year if they're not available yet.
Yes the extender is the new 22700 Panasonic battery.Bike is in stock in So Cal
At a given sag, some bikes feel plush, some other stiff or even harsh. How the two bikes compare?WDYM? Do you mean less flexy? Suspension is as stiff as you set the damping and spring so I'm not sure what you're asking.
Thanks for the tip !!I’ve been playing around with the motor tune on my 22 advanced and even with the motor set at 20nm in eco it still seems really powerful, and that’s on a 22kg bike. So I assume you guy’s lucky enough to get your hands on the elite will be able to down tune the motor significantly to eek out the range. Very interested to see your results.
It looks like it just might accept a 2.8 it would require a fit test.Question for anyone who has the Elite. The stock rear wheel spec says 27.5x2.4" but I was wondering if you can fit a 27.5x2.8" plus size on the rear? From the pictures it looks pretty tight for the rear wheel? Thanks!
So will you be taking one ?I just got back from looking at the Medium Trance X Advanced E+ Elite 3. $6000, alloy rear triangle. Just for clarity since Giant is insane on their naming!
I was kind of blown away.
Yes, it looked like you could get a wider tire on the back. The 27.5x2.4" Maxxis (which runs a little narrow, I think) Dissector had enough room that I'd say there's no question that a 2.6" of any brand would fit. 2.8 might be worth a look, but it's hard to say.
I was looking at the Pivot Shuttle SL at $9k and 40-ish without pedals.
This came in at 46 pounds even WITH alloy pedals that were maybe .8lb (20.9-ish Kg), but damn, it's $3k less! I'm guessing the Elite 2 with the carbon rear triangle, no pedals and somewhat lighter components must be closing in on 43 pounds / 19.6 Kg.
For me, it only has to be light enough for my 70 year old shoulders to get onto the bike rack and it's already there, but I have so much light componentry that I could swap out laying around my basement, that dropping weigh would be easy. I just don't think it's necessary.
Anyway, nice bike, and I even dug the color!
The programmability looked top notch as well.
A Large elite 2 is 46.8 lbs WITHOUT pedals. Were you looking at a small or something? Did you actually weigh it or did the shop tell you the claimed weight? Maybe it was tubeless, the tubes are almost 1lb each.I just got back from looking at the Medium Trance X Advanced E+ Elite 3. $6000, alloy rear triangle. Just for clarity since Giant is insane on their naming!
The 2 claimed weight is 20.4 kg (45 lbs): open the Giant website, set language to german and it will show the claimed weights. The 3 is not sold in Germany, so you won't see the model and its weight.I just got back from looking at the Medium Trance X Advanced E+ Elite 3. $6000, alloy rear triangle. Just for clarity since Giant is insane on their naming!
Legit questions!A Large elite 2 is 46.8 lbs WITHOUT pedals. Were you looking at a small or something? Did you actually weigh it or did the shop tell you the claimed weight? Maybe it was tubeless, the tubes are almost 1lb each.
These bikes are absurdly heavy considering the size of the battery. This is in part due to the motor, it's one of the heaviest out there (only bosch is heavier).
The range extender is claimed to be 2.9 lbs and the mount weights like half a pound so add that on if you plan to ride longer.
I'm not trying to be Debbie Downer, I was just hugely disappointed with the weight given giant's claimed weights.
By comparison my Mondraker Crafty Carbon with 625 battery and Bosch motor is 46.5 lbs. It's a much more expensive build of course.
If you like the bike, none of this matters! Just wanted to day your estimate of the elite 2 weight is way off.
IDK. I will look at it again and also take a look at a small when they get one, thought the medium fits just like my medium Trance Advanced 29 1. I would like to look at the Elite 2 as well.So will you be taking one ?
My Elite 2 size large was 45.67 with tubes and plastic shop demo pedals during a test ride.A Large elite 2 is 46.8 lbs WITHOUT pedals. Were you looking at a small or something? Did you actually weigh it or did the shop tell you the claimed weight? Maybe it was tubeless, the tubes are almost 1lb each.
I just put 2.5 DD aggressor on after pinching a sidewall 2 miles out. I will say that a 2.8 may just fit and here are a couple of pics of the 2.5.Question for anyone who has the Elite. The stock rear wheel spec says 27.5x2.4" but I was wondering if you can fit a 27.5x2.8" plus size on the rear? From the pictures it looks pretty tight for the rear wheel? Thanks!
I'm willing to bet this bike was tubeless as that's almost exactly what the savings is, depending on how much sealant is added of course.My Elite 2 size large was 45.67 with tubes and plastic shop demo pedals during a test ride.
I will have to weigh it now without tubes and my pedals.
I bought the bike and watched them remove the tubes so that was with tubes weighed with a Park Tools scale.I'm willing to bet this bike was tubeless as that's almost exactly what the savings is, depending on how much sealant is added of course.
I'll be very interested to see how the range works out on this bike. I don't want to go faster, I just want to go on my rides and hold a lower HR. I'm guessing that approach could get more range. My focus is generally on the climb rather than cycling up for the descent so that could change the dynamic on range. If my output power = X and I can get an additional 25%-30% of X from the bike, that's my goal. I can't tell if that's realistic, though. It seems most people want to get circuits for the downhill.I just did 15.1 miles mostly on active and used 62% of the battery. I wasn’t able to capture the ride on the app after my bike disconnected. Will make sure to save the ride or screenshot in the future before disconnecting. Or maybe I will learn how the use the app properly.
The bike climbs technical single tracks in active mode quite well. I took it easy on the downhill section (rattlers are out ) but it was very nimble and the maestro suspension does maintain tire contact during braking even on chatter.
I mentioned in another post I pinched a sidewall on the rear tire. I would say don’t go tubeless with the stock rear get a DD tire first. Just my opinion.
I am still adjusting to the bike myselfI'll be very interested to see how the range works out on this bike. I don't want to go faster, I just want to go on my rides and hold a lower HR. I'm guessing that approach could get more range. My focus is generally on the climb rather than cycling up for the descent so that could change the dynamic on range. If my output power = X and I can get an additional 25%-30% of X from the bike, that's my goal. I can't tell if that's realistic, though. It seems most people want to get circuits for the downhill.
Thanks! What's your body weight ?I just did 15.1 miles mostly on active and used 62% of the battery. I wasn’t able to capture the ride on the app after my bike disconnected. Will make sure to save the ride or screenshot in the future before disconnecting. Or maybe I will learn how the use the app properly.
I am not sure about it feeling front heavy when descending but I really haven’t been down any chutes yet or steep downhills . I have one ride in. But my back feels better with a rise bar normally.Thanks! What's your body weight ?
Do you think the handlebar rise of 20 mm is ok on this bike while descending?
The head angle and stack height of the Elite are the same as the regular Trance X. Some reviews of the regular Trance X say the front feels heavy when going down and suggest the use of a higher rise handlebar.
Are the wheels spokes butted?
Yeah, my bars are 4" higher than my saddle on my medium Trance 29 mountain bike. On short sections of very steep climbs there is no front end wandering as long as I compensate with body position. I reach my horsepower limit before I hit my geometry limit. That bike has about 75 degrees on the STA and the medium Elite is 76 in low and 76.7 in high. Reach values are about equal. I think you could go high on the riser and have no problems climbing. Descending would be improved, I would think.I am not sure about it feeling front heavy when descending but I really haven’t been down any chutes yet or steep downhills . I have one ride in. But my back feels better with a rise bar normally.
The spokes are saprim which are butted spokes.
Good infoYeah, my bars are 4" higher than my saddle on my medium Trance 29 mountain bike. On short sections of very steep climbs there is no front end wandering as long as I compensate with body position. I reach my horsepower limit before I hit my geometry limit. That bike has about 75 degrees on the STA and the medium Elite is 76 in low and 76.7 in high. Reach values are about equal. I think you could go high on the riser and have no problems climbing. Descending would be improved, I would think.
A 27.5 wheel should have a diameter of 705 mm with tyre on, so 0 bb drop should be about 353 mm and 343 at 10 mm bb drop.Another data point. Not very scientific, but in the shop, with the bike geometry in low, no sag and I think 165 cranks, the bottom of the pedal is 7" above the ground. On my Trance 29 Advanced, with a 140 fork (Vs. stock 130) no sag low profile flat pedals and 175 cranks, the bottom of the pedal is 6" above the floor. Unfortunately, the Giant site shows a BB drop (10mm) but not a BB height. With a mullet I'm not sure how well that compares with a BB drop of 32mm on the Exe and a BB height of 34cm. But the Trek BB figures are mighty close to my 29er. It's pretty rocky in Utah, so these figures would seem to be good for out here.
Yep, I suppose you could figure the drop on a 29 (up front) and a 27.5 (on the back) and split the difference for a BB height half way between?A 27.5 wheel should have a diameter of 705 mm with tyre on, so 0 bb drop should be about 353 mm and 343 at 10 mm bb drop.
