Spectral:ON coil shock?
I have just bought a canyon spectral on 8.0 from 2018 and i am Always blowing through the Travel at the back, and i'm already way over the recommanded psi for my weight in my Fox dps
So is a coil shock a great Idea ? If it's the case witch coil shock ?
I Saw people saying that going for a coil will increase the Travel going from 150 to 160, because the air shock is 230x60 and coil are 230x65.
Is having more Travel is a good Idea ?
The canyon spectral on 2018 have a head angle around 67' with a 150 mm fork but the spectral 8.0 have a 160mm fork so if i understand correcly the bike should be slaker by 1' so now or would be around 66 to 65' head angle. Is that true ?
Is going 170mm UP front is a good Idea ?
Thanks for your anwser and sorry if my english is not perfect i'm french 😅
And it worked out pretty good! View attachment 33591
Hello, I'm a spectral on owner like you
I've only been using fox dps, which is pure shock for 4 years, and I'm looking for coil shak because it's broken
Someone said that if you use a coil shock on a yoke strut, the shaft of the coil shak will become overloaded and break, which can also lead to frame damage
Has your coil shock setup been available for a long period of time without any problems?
I fitted marzocchi bomber cr 260mmx62.5mm big improvement over the air shock also fitted the coil conversion kit to the fox36 rythem forks can just blast throught anything now. Only problem i had was the water bottle rubbing on the spring so removed cage and soaked it in boiling water and bent it back refitted and bottle clears the spring.
fox DHX2 230x65 loving the coil
Im going to test my dhx2 tomorrow, need space for the 630wh next month
View attachment 52270View attachment 52271View attachment 52272
View attachment 29612View attachment 29612
Yes the dhx2 fits perfect and gone 230x65 once you get it set up there’s no bob peddling and loads of grip/plush,win win all the way
    Join 43,284
