Swannking
For the 3 motor mounting bolts/nuts, what is the torque specs?
35-40NMFor the 3 motor mounting bolts/nuts, what is the torque specs?
They lean on the motor mounts anyway, so with tightening them you just press them together (motor holders with motor mounts), so the material should not suffer. But double check that there is no space between them prior tightening.
As long as you have everything, I build them up for freeHow much would a bike store in the U.K. charge to put one of these together?
For Info :With each frame build, I will make a separate thread, specific to that frame (with the exception of the E10, as I'm sure the moderators would simply close any new E10 threads).
Duly noted.For Info :
You can make as many E10 threads as you wish.
The only thread which was locked was the one where you wished to write about every Bafang motor in the same thread. This would have been convoluted and difficult for people to find information, therefore it was proposed you wrote in the relevant existing threads which existed for each motor type.
As long as you have everything, I build them up for free![]()
Managed to sort this issue. The metal pin that is used in place of the B screw has m4 threads. So I was able to unscrew it, and the drill and tap a second hole. That gave just enough clearance for the chain to pas between the rear hub cog, and the upper tensioner wheel.
PM when you're good and readyMassively appreciated.
Id have to get you at least a decent bottle or something.
I purchased the tensioner directly from Kindernay, as well as the 22t chain ring which fouls on it. (which is a KMC). At no point anywhere did they say that thier chain tensioner won't work with thier 22t large cog.This is Problem Solvers chain tensioner and it is designed to accommodate 18t cog maximum
PM when you're good and ready![]()
Earlier in the thread Timal has a hookup to get one for $340 USD, send him a message and see if he can help you Dengfu E22 Frame ThreadThis happens when your nephew takes the bike to a spin, but you still havent set up the rear derauiler.
There were a few gears where the setup was a mess, so i am looking for that EDS from wheeltop (i saw a video where you can set every gear individually via app). Anyone has any good source to buy it from? It is cca 505€ on aliexpress..
Why do you not use a SRAM AXS? Its cheaper.It happened when he hit the snow and the bike suddenly almost stopped, he hit the throttle and then you can imagine what sounds he was hearing. I already contacted Timal, but got no answer, will look into some videos on youtube if there is any other store mentioned to buy it from.
However I did found an article, that wheeltop probably removed it from his site, perhaps sram has something to do with this. I think I am gonna have to grab one via aliexpress if it is still available. One more photo of my build, i still have to arrange the cables in front.
I am not sure if it is compatibile with microspline shimano rachet/chainring and/if manual adjustments are possible if there is any offset between shimano and sram gears..Why do you not use a SRAM AXS? Its cheaper.
The Kindernay rear chain tensioner is about to self destruct on my bike. It has not even done 500kms. And the brass bushings in the tensioner swing arm have collapsed.This is Problem Solvers chain tensioner and it is designed to accommodate 18t cog maximum
No, it was all aligned with the cog. The pulley wheel that is closest to the main cog is still in good alignment. As it rotates over the axis of arm pivot. So is not subject to any twisting as the arm deflects. (Although with alot of side to side slop, as it has a sintered bronze bush instead of a ball bearing in its point of rotation.)That's interesting failure. My tensioner has many southlands miles under the rain and has no issues. Maybe it was out of alignment with the cog?
Pretty sure the 4 slot type terminals are battery positive and BMS negative. (2 terminals each)Hi guys, do you have a wiring diagram for bafang E10/E22 battery? I need to figure out what wires go to golden pins (the button connectors) from the BMS. Do you also know if there is a way to reset the BMS?
Thank you for reply. I will get back to your comment again later as for now I have no idea what 4 slot type terminal is. I am trying to fix a lemon that i bought so was looking for a wiring diagram from BMS to those pins. The battery now gives incorrect data, I will need to rewire it.Pretty sure the 4 slot type terminals are battery positive and BMS negative. (2 terminals each)
And the BMS switch is the 2 circular contractors above.
If you look at the battery mounting block with the connector in it, you can kinda follow the wires under the silicone adhesives, on the rear side of the block.
