Dado most of what the USA guy is saying has yet to be proven ( I'm not sure but he is saying his display max's out at 750W, that may not mean that the motor doesn't produce more ). He has problems understanding that the M600 needs to have a higher cadence than the Brose motor he is comparing it to. Lets not make assumptions based on one user.
I'm that user.
To be clear guys I do not have problems understanding the cadence issues.
I fully understand that the cranks need to spin faster to make power when compared to the Brose. Also I have a deep understanding of EV systems and have built electric motorcycles from scratch and even won land speed record with them at the Bonneville salt flats in 2008. I say that only to remove the belief that I'm somehow "confused".
If I have failed in some manner, it is to explain the issue I'm seeing (which may or may not be related to firmware.)
What I know is this: In VERY steep sections of climb I can't keep up with another rider on a Levo. I am in shape and he is recovering from valve replacement surgery and is 80. I get up the hill fast. Just not as fast as him.
I have found I need to drop down a couple gears from his cadence to dig into the motor's power band (yes by spinning the cranks faster!
) and in doing so I simply end up moving slower up the steep sections and see the motor putting out about 400w. I CAN increase wattage to like 650w by further lowering gears but then I lose more speed.
I would not even think something is wrong except all I hear is "The m600 beats everything all the time" (that's a paraphrase but you catch my meaning) and mine apparently does not.
Yes, I get it... you say "pedal harder" I AM pedaling plenty hard. We all can agree that if someone pedals hard enough they could beat him up the hill, even without a motor. All I'm saying is if beating him requires some peak or even high athletic output then the m600 fails to fit into the "The m600 beats everything all the time" category.
So I started asking you knowledgeable folks if you think something might be broken or set wrong and during that process I learned I have a new' firmware ( I shared on this board the 64.9 bin I managed to get and I trust
@Kyokushin will put it up in the git for all to use ). Part of that process showed that my DPC18 display is capped (only visually) at 750w and for others it goes up to 1500w. I'm NOT saying the display limits the wattage - I'm only saying it looks different.
I will test the hill again with the weak-hearted octogenarian on a Levo with 2 changes,
a) 64.7 firmware
b) a throttle to artificially boost watts and just see what happens ( I have never ridden with the throttle)
A quick test on the flats left me feeling no obvious difference between 64.7 and 64.9. And to be clear I would not be surprised if firmware ends up being NOT the issue. For all I know there could easily be another problem.
Sorry for the TL : DR - my goal is only to help us M600 owners enjoy our builds more.
