As B biker knows i got my hands on a Cube 140 stereo so between working my nuts off to pay the debt back for these bikes and parts ive just about managed to get on a bikeWhat are you waiting for?
It’s a 10 minute plug & play job!![]()
So, I managed to get the Torx screw out slightly, enough to allow me to slip a junior hacksaw in between the sensor and the frame and cut the screw off. Unless I can drill what remains of the screw out, then the sensor is never going back to its original location - unless I cable tie it, I guess?attempted the hack this afternoon. Epic fail. Used a T20 torx screwdriver to remove the torx screw that holds in the sensor but it was driven in so tight I’ve damaged the screw when trying to unscrew it, and no way is it coming out now. In such an awkward, recessed spot too.
Damn!
Any ideas of a remedy? Take it to a bike shop and get a specialist to remove it?
A 38T front chainring is the most common mod most people do.
In regards to swapping out the chainring, is it just a case of unbolting the pedal, then the 4 x Allen screws, then it’s just a straight swap? Does the chain need adjusting or is the diameter of the old and new chainrings exactly the same?That’s ideal but, try a cheap 38T from the likes of AliExpress first. Worth a try for the sake of about a fiver!
Can’t see a firmware update option but I wouldn’t want to as it works fine and might stop my derestricter working.Can you update the firmware?
if i chqnge the old remote with the allround it will connect?
You can use an adjustable handlebar stemHello everyone my first post. I’m thinking of raising my handle bar height. What product would everyone recommend and anything I should be cautious about?
no link?This is the seat post i have install
I did have the Suntour but that was only 40mm suspension post.
Where as this is a dropper post and air adjustable suspension post
I really like it
no link?
www.pnwcomponents.co.uk
Clearly, if within your 2 year warranty, return it to Decathlon. My experience has been very positive with warranty issues.just after 1 year the motor started to click/clank when turning/adding weight to pedals.
First I thought it was the cheap plastic pedals. but NO.
if I just hold the 2 cranks I can reproduct the click sounds and I can feel some play.
I tried to remove the cranks, clean/greases but torque it up. But still make a clanking sounds.
Anything else I can check? - think the bearing are gone in the motor![]()
If out of warranty, this guy is the expert:-
Click here
