Could you revise the equations so it doesn't count reductions in burned kcal? When my heart rate is less than 50 such as before I start riding, burned kcal values are decreasing, as if energy is being added to my body.time, heart rate, rider weight
It's impossible, because burned kcal is equal the average heart rate multiplied to the timeCould you revise the equations so it doesn't count reductions in burned kcal? When my heart rate is less than 50 such as before I start riding, burned kcal values are decreasing, as if energy is being added to my body.
Hm. Please export your session into STRide format and send to meHere are parts of a data set where the burned kcal value decreased. It happened on another ride, but less frequently.
Hi vadll,
Scheme:
is it possibile to make a dash without the speedometer ?
i see in Post #126
Speedometer new visualization (can be configurable ON/OFF and Color at Settings)
that sounds the entire space can be used for the Items e.g Mod Rng Cad etc. ?
please do you have a List for all XML Entries for config own Dashes ?
nanu
Yes, it's available Online (Android only)is it possibile to make a dash without the speedometer ?
This message only occurs if the Android system itself interrupts the connection with the sensor and informs the app about it. There is no way to control the quality of the connection between the sensor and the Android system.sorry...... I have problems with the HR sensor.
I get the feedback via voice: HR Connect but no value is displayed.
After a few minutes a voice message: HR disconnect
the sensor works perfectly with the Shimano Ride app.
all (5) online Schemes are with speedometer ?Yes, it's available Online (Android only)
<dash_scheme visible="0"without the speedometer ?
i look into the xml and cannot find any hints to disable the s-meter
The new version for Android is available. It's possible to expand dash on a full screen (hide the speedometer) by double-tap. Also it's possible to expand map/dash on a full screen at "Map" page<dash_scheme visible="0"
Here is the list:in Post # 307 my Shimano Ride app Picture
what are the XML Names for E-Bike Total (km) and E-Bike Dst(km) ?
Here is the list:
STRide Params list
docs.google.com
Email sentOr alternatively if I can send you a log to understand what the problem could be.
SC-E5000 doesn't have Bluetooth features.Where is the problem ?
You can change the display to a supported one (E6xxx, E7000, EM800) and sell WU111 or you can get EW-EN100 instead of WU111What can replace the WU111?
Ok. I'll fix that. Thankshi vadll
when several Shimano motors are present i have problems with the connection
Apparently the motor with the strongest signal is recognized by the app ....is not always mine
solution: fixed bonding ??
thanks
I've posted the new version on Google Play. You can switch ON the setting "Automatic connection to known devices only" and then, during the connection, select which device you want to connect. After the first successful connection the device will be stored and then you'll connect with this device automatically.solution: fixed bonding ??
thanks
Let me know how it works for you
Is there a way to customise the display to show thing only I want to see.
